[求助] 自己編譯rewrite后網(wǎng)站無(wú)法打開(kāi)
當(dāng)初下的wdos 1.0 選的是2,可是安后發(fā)現(xiàn)沒(méi)有web環(huán)境和 wdcp,好像就是個(gè)base,懷疑安裝錯(cuò)了,重新安裝一次問(wèn)題依舊,先不管了,看到有新的rmp包后裝上了,感覺(jué)還不錯(cuò),先建幾個(gè)站點(diǎn),大問(wèn)題沒(méi)有。于是不再去想為什么接著用。
前不久發(fā)現(xiàn)了自己的drupal7打不開(kāi)clean urls,搜索后( http://drupal.org/node/15365 )得知需要改一些東西,于是動(dòng)手了。具體過(guò)程如下:
先是 /www/wdlinux/apache/bin/httpd -l  看到有了mod_rewrite.c  可是在那里呢?怎么沒(méi)有找到?
網(wǎng)上說(shuō)在apache目錄下修改httpd.conf. 在文件中 確定開(kāi)啟mod_rewrite模塊 ( LoadModule rewrite_module modules/mod_rewrite.so)可是/www/wdlinux/httpd-2.2.22/modules下面并沒(méi)有mod_rewrite.so,就有了自己編譯一個(gè)mod_rewrite.so的想法。
接著便是下載lanmp_v2.4.tar.gz (http://dl.wdlinux.cn:5180/lanmp_v2.4.tar.gz)在mappers 里面找到了mod_rewrite.c
執(zhí)行命令 /www/wdlinux/apache/bin/apxs -c mod_rewrite.c
然后 /www/wdlinux/apache/bin/apxs -i -a -n mod_rewrite mod_rewrite.la
得到結(jié)果
  1. /www/wdlinux/httpd-2.2.22/build/instdso.sh SH_LIBTOOL='/www/wdlinux/httpd-2.2.22/build/libtool' mod_rewrite.la /www/wdlinux/httpd-2.2.22/modules
  2. /www/wdlinux/httpd-2.2.22/build/libtool --mode=install cp mod_rewrite.la /www/wdlinux/httpd-2.2.22/modules/
  3. cp .libs/mod_rewrite.so /www/wdlinux/httpd-2.2.22/modules/mod_rewrite.so
  4. cp .libs/mod_rewrite.lai /www/wdlinux/httpd-2.2.22/modules/mod_rewrite.la
  5. cp .libs/mod_rewrite.a /www/wdlinux/httpd-2.2.22/modules/mod_rewrite.a
  6. chmod 644 /www/wdlinux/httpd-2.2.22/modules/mod_rewrite.a
  7. ranlib /www/wdlinux/httpd-2.2.22/modules/mod_rewrite.a
  8. PATH="$PATH:/sbin" ldconfig -n /www/wdlinux/httpd-2.2.22/modules
  9. ----------------------------------------------------------------------
  10. Libraries have been installed in:
  11.    /www/wdlinux/httpd-2.2.22/modules
  12. If you ever happen to want to link against installed libraries
  13. in a given directory, LIBDIR, you must either use libtool, and
  14. specify the full pathname of the library, or use the `-LLIBDIR'
  15. flag during linking and do at least one of the following:
  16.    - add LIBDIR to the `LD_LIBRARY_PATH' environment variable
  17.      during execution
  18.    - add LIBDIR to the `LD_RUN_PATH' environment variable
  19.      during linking
  20.    - use the `-Wl,--rpath -Wl,LIBDIR' linker flag
  21.    - have your system administrator add LIBDIR to `/etc/ld.so.conf'
  22. See any operating system documentation about shared libraries for
  23. more information, such as the ld(1) and ld.so(8) manual pages.
  24. ----------------------------------------------------------------------
  25. chmod 755 /www/wdlinux/httpd-2.2.22/modules/mod_rewrite.so
  26. [activating module `mod_rewrite' in /www/wdlinux/httpd-2.2.22/conf/httpd.conf]
modules目錄下有了mod_rewrite.so文件。
httpd.conf里面有了LoadModule rewrite_module modules/mod_rewrite.so
重新啟動(dòng),悲劇就發(fā)生了,所有站點(diǎn)都是打不開(kāi)的,連錯(cuò)誤信息都沒(méi)有……
我哪步錯(cuò)了?
這么奇怪
默認(rèn)是支持了mod_rewrite的,你說(shuō)看不到
wdos安裝,也沒(méi)有安裝到
再者,編譯這個(gè)后,重起沒(méi)有任何提示???
    是的,安裝wdos后當(dāng)時(shí)也很奇怪,但是沒(méi)在意,看到http://m.gps-cemuyi.cn/bbs/viewthread.php?tid=2751的帖子,才感覺(jué)可能不是個(gè)案,也許是硬件的關(guān)系我想。
按理,是不應(yīng)該跟硬件有關(guān)的
如果硬件原因,可能是全裝不了,一般不會(huì)一部分裝不了
回復(fù) 3# sr100fen
    你下載的wdos是什么版本  給你下載的那個(gè)連接給我  我試試
回復(fù) 5# marquis
    http://dl.wdlinux.cn:5180/wdos/iso/wdOS-1.0-i386.iso
老機(jī)器,所以下的32位,光驅(qū)用的usb外接的。自己的電腦,磁盤(pán)全部重新分區(qū),分區(qū)是只有/boot和/和swap,(好像系統(tǒng)會(huì)分個(gè)別的什么,如下圖)ip什么的都是自動(dòng)分配
  1. df -lh
  2. Filesystem            Size  Used Avail Use% Mounted on
  3. /dev/hda2              35G   16G   18G  47% /
  4. /dev/hda1              99M   12M   83M  13% /boot
  5. tmpfs                 502M     0  502M   0% /dev/shm
還有
  1. fdisk -l
  2. Disk /dev/hda: 40.0 GB, 40007761920 bytes
  3. 255 heads, 63 sectors/track, 4864 cylinders
  4. Units = cylinders of 16065 * 512 = 8225280 bytes
  5.    Device Boot      Start         End      Blocks   Id  System
  6. /dev/hda1   *           1          13      104391   83  Linux
  7. /dev/hda2              14        4724    37841107+  83  Linux
  8. /dev/hda3            4725        4863     1116517+  82  Linux swap / Solaris
  9. /dev/hda4            4864        4864        8032+   5  Extended
  10. /dev/hda5            4864        4864        8001   8e  Linux LVM
順便問(wèn)下,安裝后主機(jī)名,教程里是wdos ,而我是localhost,有問(wèn)題么 ?還有筆記本可以裝么?
