[求助] 怎么把home掛載改成www目錄
傲游截圖20151218183943.png 請問怎么把home改成/www目錄?
我是菜鳥不會弄這個!用sh /www/wdlinux/tools/wdcp_disk_xvdb.sh小工具也不行,
#!/bin/sh
disk='/dev/xvdb'
dir='/www'
chk_fstab_1=`grep ${dir} /etc/fstab | wc -l`
chk_fstab_2=`grep ${disk}1 /etc/fstab | wc -l`
if [ $chk_fstab_1 -ne 0 ]; then
        exit
fi
if [ $chk_fstab_2 -ne 0 ]; then
        exit
fi
fdisk_exit=`fdisk -l | grep ${disk} | wc -l`
fdisk_done=`fdisk -l | grep ${disk}1 | wc -l | tr -d " "`
if [ $fdisk_exit -ne 0 ]; then
        if [ $fdisk_done -ne 1 ]; then
                echo -e "\n\nfdisk $disk ..."
                fdisk $disk <<EOF
n
p
1
w
EOF
                partprobe
        fi
        else
        exit
fi
sleep 10
has_format=`tune2fs -l ${disk}1 2>1 | grep "Filesystem UUID"|wc -l`
if [ $has_format -eq 0 ]; then
        echo -e "\n\nmkfs.ext3 $disk ..."
        mkfs.ext3 ${disk}1
fi
I_N=0
if [ ! -d ${dir} ]; then
        mkdir $dir
else
service wdapache stop
service pureftpd stop
service httpd stop
service mysqld stop
service nginxd stop
mv /www /wwwo
mkdir /www
I_N=1
fi
echo -e "\n\nmount $disk ..."
mount ${disk}1 $dir &> /dev/null
if [ $I_N -eq 1 ];then
mv /wwwo/* /www/
service wdapache start
service pureftpd start
service httpd start
service mysqld start
service nginxd start
fi
chk_mount=`mount  | grep /dev/xvdb2 | wc -l`
if [ $chk_mount -eq 1 ];then
        echo "${disk}1          $dir            ext3    defaults         0 0" >> /etc/fstab
fi
echo
echo "All Is OK"
echo
小工具代碼應(yīng)該怎么改?請大蝦們幫忙看看謝謝...
Disk /dev/xvdb: 95.6 GB, 95563022336 bytes
255 heads, 63 sectors/track, 11618 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x0006cde7
    Device Boot      Start         End      Blocks   Id  System
/dev/xvdb1               1       11618    93321553+  83  Linux
Disk /dev/xvda: 10.7 GB, 10737418240 bytes
255 heads, 63 sectors/track, 1305 cylinders
Disk identifier: 0x000858c5
/dev/xvda1   *           1          64      512000   83  Linux
Partition 1 does not end on cylinder boundary.
/dev/xvda2              64        1306     9972736   8e  Linux LVM
Disk /dev/mapper/vg_have-lv_root: 9168 MB, 9168748544 bytes
255 heads, 63 sectors/track, 1114 cylinders
Disk identifier: 0x00000000
Disk /dev/mapper/vg_have-lv_swap: 1040 MB, 1040187392 bytes
255 heads, 63 sectors/track, 126 cylinders
Disk /dev/mapper/Xvdbgroup-xvdb1: 95.5 GB, 95458164736 bytes
255 heads, 63 sectors/track, 11605 cylinders
qweqweq
沒有大蝦知道怎么弄么?
qweqweq
