[求助] eaccelerator編譯不成功,求助
本帖最后由 longyushen 于 2013-4-23 01:05 編輯
eaccelerator編譯不成功,求助日志在附件
eaccelerator.zip (3.04 KB) 或者繼續(xù)看2F和3F,由于限制長度,所以分開兩回帖發(fā),謝謝諒解
  1. --2013-04-23 00:54:57--  http://soft.vpser.net/web/eaccelerator/eaccelerator-0.9.5.3.tar.bz2
  2. Resolving soft.vpser.net... 96.44.153.111
  3. Connecting to soft.vpser.net|96.44.153.111|:80... connected.
  4. HTTP request sent, awaiting response... 416 Requested Range Not Satisfiable
  5.     The file is already fully retrieved; nothing to do.
  6. eaccelerator-0.9.5.3/
  7. eaccelerator-0.9.5.3/run-tests.php
  8. eaccelerator-0.9.5.3/shm.c
  9. eaccelerator-0.9.5.3/modules/
  10. eaccelerator-0.9.5.3/x86_spinlocks.h
  11. eaccelerator-0.9.5.3/COPYING
  12. eaccelerator-0.9.5.3/ea_info.c
  13. eaccelerator-0.9.5.3/install-sh
  14. eaccelerator-0.9.5.3/ea_restore.h
  15. eaccelerator-0.9.5.3/Makefile.global
  16. eaccelerator-0.9.5.3/config.h.in
  17. eaccelerator-0.9.5.3/configure.in
  18. eaccelerator-0.9.5.3/config.m4
  19. eaccelerator-0.9.5.3/build/
  20. eaccelerator-0.9.5.3/build/libtool.m4
  21. eaccelerator-0.9.5.3/build/scan_makefile_in.awk
  22. eaccelerator-0.9.5.3/build/mkdep.awk
  23. eaccelerator-0.9.5.3/build/shtool
  24. eaccelerator-0.9.5.3/debug.c
  25. eaccelerator-0.9.5.3/Makefile.fragments
  26. eaccelerator-0.9.5.3/config.w32
  27. eaccelerator-0.9.5.3/mm.h
  28. eaccelerator-0.9.5.3/opcodes.c
  29. eaccelerator-0.9.5.3/session.h
  30. eaccelerator-0.9.5.3/Makefile
  31. eaccelerator-0.9.5.3/win32/
  32. eaccelerator-0.9.5.3/win32/eLoader.vcproj
  33. eaccelerator-0.9.5.3/win32/eAccelerator.dsw
  34. eaccelerator-0.9.5.3/win32/eAccelerator.sln
  35. eaccelerator-0.9.5.3/win32/eAccelerator.dsp
  36. eaccelerator-0.9.5.3/win32/eAccelerator.vcproj
  37. eaccelerator-0.9.5.3/win32/eLoader.dsp
  38. eaccelerator-0.9.5.3/ea_info.h
  39. eaccelerator-0.9.5.3/config.guess
  40. eaccelerator-0.9.5.3/Makefile.in
  41. eaccelerator-0.9.5.3/ea_restore.c
  42. eaccelerator-0.9.5.3/eLoader/
  43. eaccelerator-0.9.5.3/eLoader/config.m4
  44. eaccelerator-0.9.5.3/eLoader/Makefile.in
  45. eaccelerator-0.9.5.3/eLoader/autogen.sh
  46. eaccelerator-0.9.5.3/autom4te.cache/
  47. eaccelerator-0.9.5.3/autom4te.cache/output.0
  48. eaccelerator-0.9.5.3/autom4te.cache/requests
  49. eaccelerator-0.9.5.3/autom4te.cache/traces.0
  50. eaccelerator-0.9.5.3/content.c
  51. eaccelerator-0.9.5.3/ea_dasm.h
  52. eaccelerator-0.9.5.3/include/
  53. eaccelerator-0.9.5.3/doc/
  54. eaccelerator-0.9.5.3/doc/phpdoc.ini
  55. eaccelerator-0.9.5.3/doc/php/
  56. eaccelerator-0.9.5.3/doc/php/info.php
  57. eaccelerator-0.9.5.3/doc/php/shared_memory.php
  58. eaccelerator-0.9.5.3/doc/php/examples/
  59. eaccelerator-0.9.5.3/doc/php/examples/eaccelerator_cache_output.php
  60. eaccelerator-0.9.5.3/doc/php/examples/eaccelerator_cache_result.php
  61. eaccelerator-0.9.5.3/doc/php/examples/eaccelerator_cache_page.php
  62. eaccelerator-0.9.5.3/doc/php/examples/eaccelerator_lock.php
  63. eaccelerator-0.9.5.3/doc/php/session.php
  64. eaccelerator-0.9.5.3/doc/php/dasm.php
  65. eaccelerator-0.9.5.3/doc/php/encoder.php
  66. eaccelerator-0.9.5.3/doc/php/loader.php
  67. eaccelerator-0.9.5.3/doc/php/cache.php
  68. eaccelerator-0.9.5.3/config.log
  69. eaccelerator-0.9.5.3/eaccelerator_version.h
  70. eaccelerator-0.9.5.3/optimize.c
  71. eaccelerator-0.9.5.3/missing
  72. eaccelerator-0.9.5.3/README.win32
  73. eaccelerator-0.9.5.3/README
  74. eaccelerator-0.9.5.3/config.status
  75. eaccelerator-0.9.5.3/ltmain.sh
  76. eaccelerator-0.9.5.3/loader.c
  77. eaccelerator-0.9.5.3/ea_store.h
  78. eaccelerator-0.9.5.3/bugreport.php
  79. eaccelerator-0.9.5.3/cache.c
  80. eaccelerator-0.9.5.3/mm.c
  81. eaccelerator-0.9.5.3/PHP_Highlight.php
  82. eaccelerator-0.9.5.3/mkinstalldirs
  83. eaccelerator-0.9.5.3/cache.h
  84. eaccelerator-0.9.5.3/control.php
  85. eaccelerator-0.9.5.3/aclocal.m4
  86. eaccelerator-0.9.5.3/session.c
  87. eaccelerator-0.9.5.3/opcodes.h
  88. eaccelerator-0.9.5.3/NEWS
  89. eaccelerator-0.9.5.3/config.h
  90. eaccelerator-0.9.5.3/debug.h
  91. eaccelerator-0.9.5.3/.deps
  92. eaccelerator-0.9.5.3/content.h
  93. eaccelerator-0.9.5.3/Makefile.objects
  94. eaccelerator-0.9.5.3/dasm.php
  95. eaccelerator-0.9.5.3/encoder.php
  96. eaccelerator-0.9.5.3/config.nice
  97. eaccelerator-0.9.5.3/eaccelerator.h
  98. eaccelerator-0.9.5.3/shm.h
  99. eaccelerator-0.9.5.3/acinclude.m4
  100. eaccelerator-0.9.5.3/eaccelerator.c
  101. eaccelerator-0.9.5.3/configure
  102. eaccelerator-0.9.5.3/config.sub
  103. eaccelerator-0.9.5.3/libtool
  104. eaccelerator-0.9.5.3/AUTHORS
  105. eaccelerator-0.9.5.3/README.eLoader
  106. eaccelerator-0.9.5.3/ea_store.c
  107. eaccelerator-0.9.5.3/encoder.c
  108. eaccelerator-0.9.5.3/ea_dasm.c
  109. eaccelerator-0.9.5.3/ChangeLog
  110. eaccelerator-0.9.5.3/eaccelerator.ini
  111. checking for grep that handles long lines and -e... /bin/grep
  112. checking for egrep... /bin/grep -E
  113. checking for a sed that does not truncate output... /bin/sed
  114. checking for gcc... gcc
  115. checking for C compiler default output file name... a.out
  116. checking whether the C compiler works... yes
  117. checking whether we are cross compiling... no
  118. checking for suffix of executables...
  119. checking for suffix of object files... o
  120. checking whether we are using the GNU C compiler... yes
  121. checking whether gcc accepts -g... yes
  122. checking for gcc option to accept ISO C89... none needed
  123. checking whether gcc and cc understand -c and -o together... yes
  124. checking if compiler supports -R... no
  125. checking if compiler supports -Wl,-rpath,... yes
  126. checking build system type... x86_64-unknown-linux-gnu
  127. checking host system type... x86_64-unknown-linux-gnu
  128. checking target system type... x86_64-unknown-linux-gnu
  129. checking for PHP prefix... /www/wdlinux/nginx_php-5.2.17
  130. checking for PHP includes... -I/www/wdlinux/nginx_php-5.2.17/include/php -I/www/wdlinux/nginx_php-5.2.17/include/php/main -I/www/wdlinux/nginx_php-5.2.17/include/php/TSRM -I/www/wdlinux/nginx_php-5.2.17/include/php/Zend -I/www/wdlinux/nginx_php-5.2.17/include/php/ext -I/www/wdlinux/nginx_php-5.2.17/include/php/ext/date/lib
  131. checking for PHP extension directory... /www/wdlinux/nginx_php-5.2.17/lib/php/extensions/no-debug-non-zts-20060613
  132. checking for PHP installed headers prefix... /www/wdlinux/nginx_php-5.2.17/include/php
  133. checking for re2c... no
  134. configure: WARNING: You will need re2c 0.9.11 or later if you want to regenerate PHP parsers.
  135. checking for gawk... gawk
  136. checking whether to enable eaccelerator support... yes, shared
  137. checking how to run the C preprocessor... gcc -E
  138. checking for ANSI C header files... yes
  139. checking for sys/types.h... yes
  140. checking for sys/stat.h... yes
  141. checking for stdlib.h... yes
  142. checking for string.h... yes
  143. checking for memory.h... yes
  144. checking for strings.h... yes
  145. checking for inttypes.h... yes
  146. checking for stdint.h... yes
  147. checking for unistd.h... yes
  148. checking for unistd.h... (cached) yes
  149. checking limits.h usability... yes
  150. checking limits.h presence... yes
  151. checking for limits.h... yes
  152. checking sys/param.h usability... yes
  153. checking sys/param.h presence... yes
  154. checking for sys/param.h... yes
  155. checking sched.h usability... yes
  156. checking sched.h presence... yes
  157. checking for sched.h... yes
  158. checking mandatory system headers... yes
  159. checking whether union semun is defined in sys/sem.h... no
  160. checking for sysvipc shared memory support... yes
  161. checking for mmap shared memory support... yes
  162. checking for mmap on /dev/zero shared memory support... yes
  163. checking for anonymous mmap shared memory support... yes
  164. checking for posix mmap shared memory support... no
  165. checking for best shared memory type... anonymous mmap
  166. checking for spinlock semaphores support... yes
  167. checking for pthread semaphores support... no
  168. checking for posix semaphores support... no
  169. checking for sysvipc semaphores support... yes
  170. checking for fcntl semaphores support... yes
  171. checking for flock semaphores support... yes
  172. checking for best semaphores type... spinlock
  173. checking for sched_yield... yes
  174. checking for mprotect... yes
  175. checking for ext/session/php_session.h... yes
  176. checking for ld used by gcc... /usr/bin/ld
  177. checking if the linker (/usr/bin/ld) is GNU ld... yes
  178. checking for /usr/bin/ld option to reload object files... -r
  179. checking for BSD-compatible nm... /usr/bin/nm -B
  180. checking whether ln -s works... yes
  181. checking how to recognise dependent libraries... pass_all
  182. checking dlfcn.h usability... yes
  183. checking dlfcn.h presence... yes
  184. checking for dlfcn.h... yes
  185. checking for g++... g++
  186. checking whether we are using the GNU C++ compiler... yes
  187. checking whether g++ accepts -g... yes
  188. checking how to run the C++ preprocessor... g++ -E
  189. checking for g77... no
  190. checking for xlf... no
  191. checking for f77... no
  192. checking for frt... no
  193. checking for pgf77... no
  194. checking for cf77... no
  195. checking for fort77... no
  196. checking for fl32... no
  197. checking for af77... no
  198. checking for xlf90... no
  199. checking for f90... no
  200. checking for pgf90... no
  201. checking for pghpf... no
  202. checking for epcf90... no
  203. checking for gfortran... no
  204. checking for g95... no
  205. checking for xlf95... no
  206. checking for f95... no
  207. checking for fort... no
  208. checking for ifort... no
  209. checking for ifc... no
  210. checking for efc... no
  211. checking for pgf95... no
  212. checking for lf95... no
  213. checking for ftn... no
  1. checking whether we are using the GNU Fortran 77 compiler... no
  2. checking whether  accepts -g... no
  3. checking the maximum length of command line arguments... 32768
  4. checking command to parse /usr/bin/nm -B output from gcc object... ok
  5. checking for objdir... .libs
  6. checking for ar... ar
  7. checking for ranlib... ranlib
  8. checking for strip... strip
  9. checking if gcc supports -fno-rtti -fno-exceptions... no
  10. checking for gcc option to produce PIC... -fPIC
  11. checking if gcc PIC flag -fPIC works... yes
  12. checking if gcc static flag -static works... no
  13. checking if gcc supports -c -o file.o... yes
  14. checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
  15. checking whether -lc should be explicitly linked in... no
  16. checking dynamic linker characteristics... GNU/Linux ld.so
  17. checking how to hardcode library paths into programs... immediate
  18. checking whether stripping libraries is possible... yes
  19. checking if libtool supports shared libraries... yes
  20. checking whether to build shared libraries... yes
  21. checking whether to build static libraries... no
  22. configure: creating libtool
  23. appending configuration tag "CXX" to libtool
  24. checking for ld used by g++... /usr/bin/ld -m elf_x86_64
  25. checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes
  26. checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
  27. checking for g++ option to produce PIC... -fPIC
  28. checking if g++ PIC flag -fPIC works... yes
  29. checking if g++ static flag -static works... no
  30. checking if g++ supports -c -o file.o... yes
  31. checking whether the g++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
  32. checking dynamic linker characteristics... GNU/Linux ld.so
  33. checking how to hardcode library paths into programs... immediate
  34. appending configuration tag "F77" to libtool
  35. configure: creating ./config.status
  36. config.status: creating config.h
  37. /bin/sh /tmp/eaccelerator-0.9.5.3/libtool --mode=install cp ./eaccelerator.la /tmp/eaccelerator-0.9.5.3/modules
  38. cp ./.libs/eaccelerator.so /tmp/eaccelerator-0.9.5.3/modules/eaccelerator.so
  39. cp ./.libs/eaccelerator.lai /tmp/eaccelerator-0.9.5.3/modules/eaccelerator.la
  40. PATH="$PATH:/sbin" ldconfig -n /tmp/eaccelerator-0.9.5.3/modules
  41. ----------------------------------------------------------------------
  42. Libraries have been installed in:
  43.    /tmp/eaccelerator-0.9.5.3/modules
  44. If you ever happen to want to link against installed libraries
  45. in a given directory, LIBDIR, you must either use libtool, and
  46. specify the full pathname of the library, or use the `-LLIBDIR'
  47. flag during linking and do at least one of the following:
  48.    - add LIBDIR to the `LD_LIBRARY_PATH' environment variable
  49.      during execution
  50.    - add LIBDIR to the `LD_RUN_PATH' environment variable
  51.      during linking
  52.    - use the `-Wl,--rpath -Wl,LIBDIR' linker flag
  53.    - have your system administrator add LIBDIR to `/etc/ld.so.conf'
  54. See any operating system documentation about shared libraries for
  55. more information, such as the ld(1) and ld.so(8) manual pages.
  56. ----------------------------------------------------------------------
  57. Build complete.
  58. Don't forget to run 'make test'.
  59. Installing shared extensions:     /www/wdlinux/nginx_php-5.2.17/lib/php/extensions/no-debug-non-zts-20060613/
  60. Stopping nginx: [  OK  ]
  61. Shutting down php_fpm . done
  62. Starting nginx: [  OK  ]
  63. Starting php_fpm  done
用哪個安裝的?
用哪個安裝的?
admin 發(fā)表于 2013-4-23 09:23
   http://m.gps-cemuyi.cn/bbs/viewthread.php?tid=18是安裝這個帖子搞的
我看不像
