[求助] 安裝gcc、lanmp時出錯,麻煩幫忙看看。
Total        340 kB/s |  36 MB     01:48
Running rpm_check_debug
Running Transaction Test
memory alloc (4194304 bytes) returned NULL.
lanmp.sh: line 86: ntpdate: command not found
hwclock is unable to get I/O port access:  the iopl(3) call failed.
setenforce: SELinux is disabled
sed: can't read /etc/selinux/config: No such file or directory
httpd: unrecognized service
mysqld: unrecognized service
error reading information on service httpd: No such file or directory
error reading information on service mysqld: No such file or directory
error reading information on service sendmail: No such file or directory
installing mysql...
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking target system type... i686-pc-linux-gnu
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking how to create a ustar tar archive... gnutar
checking for style of include used by make... GNU
checking for gcc... no
checking for cc... no
checking for cl.exe... no
configure: error: in `/usr/downloads/lanmp/mysql-5.1.56':
主機(jī)配置:linux vps,64M 內(nèi)存 / 5G 硬盤,系統(tǒng)是centos 5.5,學(xué)習(xí)用的。
在安裝lanmp之前,我試著安裝gcc,但提示:
Transaction Summary
Install       6 Package(s)
Upgrade       4 Package(s)
Total size: 34 M
Downloading Packages:
memory alloc (16777216 bytes) returned NULL.
不曉得這是安裝成功了,還是沒成功。麻煩懂的幫忙看看。謝謝了:)
沒安裝成功,內(nèi)存溢出了
你的應(yīng)該是openvz的vps,可以問下服務(wù)商
