[求助] nginx升級(jí)1.4.1問題limit_conn_zone
我把nginx升級(jí)為1.4.1后提示limit_zone不支持了!要用limit_conn_zone那我是不是把
  1. #!/bin/bash
  2. # nginx update scripts
  3. # url http://m.gps-cemuyi.cn
  4. # author wdlinux
  5. if [ ! $1 ];then
  6.         ver="1.2.9"
  7. else
  8.         ver=$1
  9. fi
  10. cd /tmp
  11. wget http://down.wdlinux.cn/in/pcre_ins.sh
  12. sh pcre_ins.sh
  13. wget -c http://nginx.org/download/nginx-$ver.tar.gz
  14. [ $? != 0 ] && echo "down err" && exit
  15. tar zxvf nginx-$ver.tar.gz
  16. cd nginx-$ver
  17. ./configure --user=www --group=www --prefix=/www/wdlinux/nginx-$ver --with-http_stub_status_module --with-http_ssl_module
  18. [ $? != 0 ] && echo "configure err" && exit
  19. make
  20. [ $? != 0 ] && echo "make err" && exit
  21. make install
  22. [ $? != 0 ] && echo "make install err" && exit
  23. mv /www/wdlinux/nginx-$ver/conf/nginx.conf /www/wdlinux/nginx-$ver/conf/nginx.conf.default
  24. cp -pR /www/wdlinux/nginx/conf/* /www/wdlinux/nginx-$ver/conf/
  25. service nginxd stop
  26. rm -f /www/wdlinux/nginx
  27. ln -sf /www/wdlinux/nginx-$ver /www/wdlinux/nginx
  28. sed -i '/limit_zone/d' /www/wdlinux/nginx/conf/nginx.conf
  29. service nginxd start
  30. echo
  31. echo
  32. echo "Nginx Update Is OK"
  33. echo "Current Ver Is:$ver"
  34. echo
中的limit_zone改為limit_conn_zone
回復(fù) 1# linaiwei
   升級(jí)后第次運(yùn)行nginx重起都提示
  1. [root@bogon ~]# service nginxd restart
  2. Stopping nginx: nginx: [emerg] invalid number of arguments in "limit_conn_zone" directive in /www/wdlinux/nginx-1.4.1/conf/nginx.conf:22
  3.                                                            [  OK  ]
  4. Shutting down php_fpm warning, no pid file found - php-fpm is not running ?
  5. Starting nginx: nginx: [emerg] invalid number of arguments in "limit_conn_zone" directive in /www/wdlinux/nginx/conf/nginx.conf:22
  6.                                                            [FAILED]
  7. Starting php_fpm PHP Warning:  PHP Startup: Invalid library (maybe not a PHP library) 'zip.so'  in Unknown on line 0
  8. done
把nginx.conf文件里的
limit_conn_zone
這行,去掉就行了
