[求助] 雙網(wǎng)卡,有一塊網(wǎng)卡ping不通。。。。
root@111111111 ~]# ifconfig
eth0      Link encap:Ethernet  HWaddr 00:24:1D:1D:73:FA
          inet addr:192.168.1.185  Bcast:192.168.1.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:71148 errors:0 dropped:0 overruns:0 frame:0
          TX packets:90586 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:10343178 (9.8 MiB)  TX bytes:73561246 (70.1 MiB)
          Interrupt:122 Base address:0x2000
eth1      Link encap:Ethernet  HWaddr 54:E6:FC:70:5A:F2
          inet addr:192.168.123.216  Bcast:192.168.123.255  Mask:255.255.255.0
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:7938 errors:15 dropped:0 overruns:0 frame:0
          TX packets:20 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:1000941 (977.4 KiB)  TX bytes:1764 (1.7 KiB)
          Interrupt:169 Base address:0x2000
[root@111111111~]# iptables -vL
Chain INPUT (policy ACCEPT 0 packets, 0 bytes)
pkts bytes target     prot opt in     out     source               destination
Chain FORWARD (policy ACCEPT 0 packets, 0 bytes)
Chain OUTPUT (policy ACCEPT 0 packets, 0 bytes)
[root@1111111111 ~]# route -n
Kernel IP routing table
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
192.168.1.0     0.0.0.0         255.255.255.0   U     0      0        0 eth0
192.168.123.0   0.0.0.0         255.255.255.0   U     0      0        0 eth1
0.0.0.0         192.168.1.1     0.0.0.0         UG    0      0        0 eth0
第一塊網(wǎng)卡可以正常工作,第二塊ping不通。。。。
是不是沒有插好,
hello
同樣遇到這個(gè)問題,不知道有沒有辦法解決
不同網(wǎng)段?
回復(fù) 4# admin
   不同網(wǎng)段的,不好保存,每一次,重啟,都要設(shè)置
