系統(tǒng)改成6.8表現(xiàn)正常了
CentOS 7.2.1511 core 下出現(xiàn)三個問題
1. apache ngix啟動失敗,提示沒有www 用戶,手動增加后httpd能啟動 ...
ht99 發(fā)表于 2016-10-25 14:56
    可能用centos7的minimal iso安裝后沒有安裝base包,6.8成功了,現(xiàn)在再試7
ht99 發(fā)表于 2016-10-26 16:27
    starting...
Shutting down MySQL. SUCCESS!
Starting MySQL.. SUCCESS!
Starting httpd (via systemctl):  Job for httpd.service failed because the control process exited with error code. See "systemctl status httpd.service" and "journalctl -xe" for details.
                                                           [FAILED]
Starting nginxd (via systemctl):  Job for nginxd.service failed because the control process exited with error code. See "systemctl status nginxd.service" and "journalctl -xe" for details.
                                                           [FAILED]
Starting memcached (via systemctl):                        [  OK  ]
Starting wdcp (via systemctl):                             [  OK  ]
Starting pureftpd (via systemctl):                         [  OK  ]
Removed symlink /etc/systemd/system/dbus-org.fedoraproject.FirewallD1.service.
Removed symlink /etc/systemd/system/basic.target.wants/firewalld.service.
Created symlink from /etc/systemd/system/basic.target.wants/iptables.service to /usr/lib/systemd/system/iptables.service.
iptables: Saving firewall rules to /etc/sysconfig/iptables: restorecon:  Warning no default label for /etc/sysconfig/iptables.save
                                                           [  OK  ]
      Congratulations ,lanmp,wdCP install is complete
      visit http://ip
      wdCP http://ip:8080
      more infomation please visit http://m.gps-cemuyi.cn/bbs/
[root@localhost ~]# service httpd start
                                                           [FAILED]
[root@localhost ~]# systemctl status httpd.service
● httpd.service - SYSV: Apache is a World Wide Web server.  It is used to serve HTML files and CGI.
   Loaded: loaded (/etc/rc.d/init.d/httpd)
   Active: failed (Result: exit-code) since Thu 2016-10-27 09:36:48 CST; 13s ago
     Docs: man:systemd-sysv-generator(8)
  Process: 70934 ExecStart=/etc/rc.d/init.d/httpd start (code=exited, status=1/FAILURE)
Oct 27 09:36:48 localhost.localdomain systemd[1]: Starting SYSV: Apache is a World Wide Web server.  It is used to serve HTML files and CGI....
Oct 27 09:36:48 localhost.localdomain httpd[70934]: Starting httpd: AH00543: httpd: bad user name www
Oct 27 09:36:48 localhost.localdomain httpd[70934]: [FAILED]
Oct 27 09:36:48 localhost.localdomain systemd[1]: httpd.service: control process exited, code=exited status=1
Oct 27 09:36:48 localhost.localdomain systemd[1]: Failed to start SYSV: Apache is a World Wide Web server.  It is used to serve HTML files and CGI..
Oct 27 09:36:48 localhost.localdomain systemd[1]: Unit httpd.service entered failed state.
Oct 27 09:36:48 localhost.localdomain systemd[1]: httpd.service failed.
[root@localhost ~]# systemctl status nginxd.service
● nginxd.service - SYSV: Nginx is an HTTP(S) server, HTTP(S) reverse proxy and IMAP/POP3 proxy server
   Loaded: loaded (/etc/rc.d/init.d/nginxd)
   Active: failed (Result: exit-code) since Thu 2016-10-27 09:34:51 CST; 2min 52s ago
Oct 27 09:34:51 localhost.localdomain systemd[1]: Starting SYSV: Nginx is an HTTP(S) server, HTTP(S) reverse proxy and IMAP/POP3 proxy server...
Oct 27 09:34:51 localhost.localdomain nginxd[70576]: Starting nginx: nginx: [emerg] getpwnam("www") failed in /www/wdlinux/nginx/conf/nginx.conf:4
Oct 27 09:34:51 localhost.localdomain nginxd[70576]: [FAILED]
Oct 27 09:34:51 localhost.localdomain systemd[1]: nginxd.service: control process exited, code=exited status=1
Oct 27 09:34:51 localhost.localdomain systemd[1]: Failed to start SYSV: Nginx is an HTTP(S) server, HTTP(S) reverse proxy and IMAP/POP3 proxy server.
Oct 27 09:34:51 localhost.localdomain systemd[1]: Unit nginxd.service entered failed state.
Oct 27 09:34:51 localhost.localdomain systemd[1]: nginxd.service failed.
增加了www用戶后好了!
--2016-10-28 03:31:31--  http://dl.wdlinux.cn/files/other/pcre-8.38.tar.gz
正在解析主機(jī) dl.wdlinux.cn... 218.85.65.150, 240e:14:1003:3::1
正在連接 dl.wdlinux.cn|218.85.65.150|:80... 已連接。
已發(fā)出 HTTP 請求,正在等待回應(yīng)... 302 Found
位置:http://127.0.0.1/ [跟隨至新的 URL]
--2016-10-28 03:31:31--  http://127.0.0.1/
正在連接 127.0.0.1:80... 失。壕芙^連接。
pcre-8.38.tar.gz download failed
http://www.vhongxing.com
CentOS 6.0和7.0系統(tǒng)下多次安裝失敗,都是mysql報錯,后來又安裝了幾次安裝成功了,但是后臺數(shù)據(jù)庫掛了phpmyadmin無法打開
安裝完后 nginx httpd 不能啟動
查看日志 沒有www用戶  手動添加www用戶后  使用正常
樓主是不是忘記加www用戶了??/
懂我的
樓主是不是忘記加 ...
csuper 發(fā)表于 2016-11-11 15:31
我是centos測試的
懂我的
老大:鳥云  CENTOS7.2 64 安裝出現(xiàn)以下提示
Delta RPMs disabled because /usr/bin/applydeltarpm not installed.
然后安裝包就只有73個了
你們試過  都怎么樣了
阿里云安裝失敗ECS配置錯誤
請問一下,這個一鍵安裝包可以安裝在ubuntu上嗎?我這里安裝的時候提示找不到y(tǒng)um和rpm命令!
https://www.zeelis.com/
root@ebs-20136:~# sh lanmp.sh
lanmp.sh: 45: lib/common.conf: function: not found
lanmp.sh: 67: lib/common.conf: Syntax error: "}" unexpected
root@ebs-20136:~#
Linux 64位(ubuntu-14.04-server)
