[教程] 關(guān)于mysql升級到5.5報錯問題
升級命令wget http://down.wdlinux.cn/in/mysql_up55.sh
sh mysql_up55.sh
安裝日志錯誤部分
Shutting down MySQL. SUCCESS!
scripts/mysql_install_db.sh: line 325: @HOSTNAME@: command not found
WARNING: The host '' could not be looked up with resolveip.
This probably means that your libc libraries are not 100 % compatible
with this binary MySQL version. The MySQL daemon, mysqld, should work
normally with the exception that host name resolving will not work.
This means that you should use IP addresses instead of hostnames
when specifying MySQL privileges !
Installing MySQL system tables...
OK
Filling help tables...
OK
To start mysqld at boot time you have to copy
support-files/mysql.server to the right place for your system
PLEASE REMEMBER TO SET A PASSWORD FOR THE MySQL root USER !
To do so, start the server, then issue the following commands:
/www/wdlinux/mysql/bin/mysqladmin -u root password 'new-password'
/www/wdlinux/mysql/bin/mysqladmin -u root -h  password 'new-password'
Alternatively you can run:
/www/wdlinux/mysql/bin/mysql_secure_installation
which will also give you the option of removing the test
databases and anonymous user created by default.  This is
strongly recommended for production servers.
See the manual for more instructions.
You can start the MySQL daemon with:
cd /www/wdlinux/mysql ; /www/wdlinux/mysql/bin/mysqld_safe &
You can test the MySQL daemon with mysql-test-run.pl
cd /www/wdlinux/mysql/mysql-test ; perl mysql-test-run.pl
Please report any problems with the /www/wdlinux/mysql/scripts/mysqlbug script!
ERROR! MySQL server PID file could not be found!
Starting MySQL. ERROR! The server quit without updating PID file (/www/wdlinux/mysql-5.5.27/data/localhost.localdomain.pid).
Running..., Please Wait...
err
mysql update is OK
錯誤情況
http://m.gps-cemuyi.cn/bbs/viewthread.php?tid=5137
安裝完后提示
重啟mysql時提示,后臺登陸不了。
解決辦法
vi /www/wdlinux/init.d/mysqld
修改46 47行的目錄為安裝目錄與數(shù)據(jù)庫目錄
哈哈
謝謝 解決問題
謝謝,OK了
我靠,這個帖子應(yīng)該加精華。
百度搜“上海千鳴網(wǎng)絡(luò)”
這個可以找admin。。。
admin少些的東西,我們集體到admin 家賴著。。。
謝謝 解決問題~~!
這個證明了,有效。。。。
非常非常感謝
jimophoto
我的無效,怎么搞得?
慧通傳媒
Installation of system tables failed!  Examine the logs in
/www/wdlinux/mysql/var for more information.
You can try to start the mysqld daemon with:
    shell> /www/wdlinux/mysql/bin/mysqld --skip-grant &
and use the command line tool /www/wdlinux/mysql/bin/mysql
to connect to the mysql database and look at the grant tables:
    shell> /www/wdlinux/mysql/bin/mysql -u root mysql
    mysql> show tables
Try 'mysqld --help' if you have problems with paths.  Using --log
gives you a log in /www/wdlinux/mysql/var that may be helpful.
Please consult the MySQL manual section
'Problems running mysql_install_db', and the manual section that
describes problems on your OS.  Another information source are the
MySQL email archives available at http://lists.mysql.com/.
Please check all of the above before submitting a bug report
at http://bugs.mysql.com/
Starting MySQL. ERROR! The server quit without updating PID file (/www/wdlinux/mysql-5.5.36/data/AY140224145940Z.pid).
err
mysql update is OK
[root@AY140224145940Z ~]#
慧通傳媒
無法連接mysql,請檢查mysql是否已啟動及用戶密碼是否設(shè)置正確!:
慧通傳媒
給力 謝謝
和11樓一樣 沒解決
不會操作,能詳細(xì)點教程不?
好東西
回復(fù) 12# q清和
     我這邊的解決方案 可以參考下 http://m.gps-cemuyi.cn/bbs/viewthread.php?tid=10582&extra=
謝謝不錯謝謝不錯謝謝不錯謝謝不錯
