[求助] WDCP V3的mysql 會(huì)不定期關(guān)閉,想查下原因,日志在哪?
error:root password123456
看看空間是不是滿了
回復(fù) 2# lanyeit
   空間沒有滿。在哪查MYSQL 的出錯(cuò)日志?一直沒有找著。
回復(fù) 2# lanyeit
   161013 10:46:12 mysqld_safe mysqld from pid file /www/wdlinux/mysql-5.5.49/data/iZbp10vmnn5rfl12msv6ciZ.pid ended161013 10:46:13 mysqld_safe Starting mysqld daemon with databases from /www/wdlinux/mysql-5.5.49/data
161013 10:46:13 [Warning] 'THREAD_CONCURRENCY' is deprecated and will be removed in a future release.
161013 10:46:13 [Note] /www/wdlinux/mysql-5.5.49/bin/mysqld (mysqld 5.5.49) starting as process 7512 ...
161013 10:46:13 [Note] Plugin 'FEDERATED' is disabled.
161013 10:46:13 InnoDB: The InnoDB memory heap is disabled
161013 10:46:13 InnoDB: Mutexes and rw_locks use GCC atomic builtins
161013 10:46:13 InnoDB: Compressed tables use zlib 1.2.3
161013 10:46:13 InnoDB: Initializing buffer pool, size = 128.0M
161013 10:46:13 InnoDB: Completed initialization of buffer pool
161013 10:46:13 InnoDB: highest supported file format is Barracuda.
161013 10:46:13  InnoDB: Waiting for the background threads to start
161013 10:46:14 InnoDB: 5.5.49 started; log sequence number 47848664
161013 10:46:14 [Note] Server hostname (bind-address): '0.0.0.0'; port: 3306
161013 10:46:14 [Note]   - '0.0.0.0' resolves to '0.0.0.0';
161013 10:46:14 [Note] Server socket created on IP: '0.0.0.0'.
161013 10:46:14 [Note] Event Scheduler: Loaded 0 events
161013 10:46:14 [Note] /www/wdlinux/mysql-5.5.49/bin/mysqld: ready for connections.
Version: '5.5.49'  socket: '/tmp/mysql.sock'  port: 3306  Source distribution
161013 14:17:01 mysqld_safe Number of processes running now: 0
161013 14:17:01 mysqld_safe mysqld restarted
161013 14:17:01 [Warning] 'THREAD_CONCURRENCY' is deprecated and will be removed in a future release.
161013 14:17:01 [Note] /www/wdlinux/mysql-5.5.49/bin/mysqld (mysqld 5.5.49) starting as process 7845 ...
161013 14:17:01 [Note] Plugin 'FEDERATED' is disabled.
161013 14:17:01 InnoDB: The InnoDB memory heap is disabled
161013 14:17:01 InnoDB: Mutexes and rw_locks use GCC atomic builtins
161013 14:17:01 InnoDB: Compressed tables use zlib 1.2.3
161013 14:17:01 InnoDB: Initializing buffer pool, size = 128.0M
InnoDB: mmap(137363456 bytes) failed; errno 12
161013 14:17:01 InnoDB: Completed initialization of buffer pool
161013 14:17:01 InnoDB: Fatal error: cannot allocate memory for the buffer pool
161013 14:17:01 [ERROR] Plugin 'InnoDB' init function returned error.
161013 14:17:01 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
161013 14:17:01 [ERROR] Unknown/unsupported storage engine: InnoDB
161013 14:17:01 [ERROR] Aborting
161013 14:17:01 [Note] /www/wdlinux/mysql-5.5.49/bin/mysqld: Shutdown complete
161013 14:17:01 mysqld_safe mysqld from pid file /www/wdlinux/mysql-5.5.49/data/iZbp10vmnn5rfl12msv6ciZ.pid ended
內(nèi)存是多大?我原來用小內(nèi)存VPS的時(shí)候也出現(xiàn)過,現(xiàn)在2G以上內(nèi)存都沒這問題了
回復(fù) 5# lanyeit
   1G內(nèi)存。
這個(gè)問題官方還是不重視嗎?貌似很普遍了,我的阿里云ECS 8G內(nèi)存,MYSQL服務(wù)時(shí)不時(shí)死掉,目前無法解決。
eastdesign
跟內(nèi)存關(guān)系不大,我搬瓦工的內(nèi)存才512M,運(yùn)行半個(gè)月沒掛過。linode內(nèi)存2G,每天掛掉一次,前天還一天掛三次。
前兩天把linode的虛擬內(nèi)存也就是交換分區(qū)增加到2.5G,貌似兩天沒掛了,破歷史記錄。
