這個(gè)服務(wù)器不行的時(shí)候,我又換了一家,但是仍然報(bào)錯(cuò),如下:
PING m.gps-cemuyi.cn (119.146.223.143) 56(84) bytes of data.
From 10.5.1.175 icmp_seq=1 Time to live exceeded
--- m.gps-cemuyi.cn ping statistics ---
1 packets transmitted, 0 received, +1 errors, 100% packet loss, time 0ms
diffutils-2.8.1-16.el5.x86_64: failure: CentOS/diffutils-2.8.1-16.el5.x86_64.rpm from base: [Errno 256] No more mirrors to try.
libgcc-4.1.2-54.el5.x86_64: failure: CentOS/libgcc-4.1.2-54.el5.x86_64.rpm from base: [Errno 256] No more mirrors to try.
2:libpng-devel-1.2.10-17.el5_8.x86_64: failure: CentOS/libpng-devel-1.2.10-17.el5_8.x86_64.rpm from base: [Errno 256] No more mirrors to try.
libtool-ltdl-1.5.22-7.el5_4.i386: failure: CentOS/libtool-ltdl-1.5.22-7.el5_4.i386.rpm from base: [Errno 256] No more mirrors to try.
freetype-devel-2.2.1-32.el5_9.1.x86_64: failure: RPMS/freetype-devel-2.2.1-32.el5_9.1.x86_64.rpm from updates: [Errno 256] No more mirrors to try.
nscd-2.5-107.el5_9.4.x86_64: failure: RPMS/nscd-2.5-107.el5_9.4.x86_64.rpm from updates: [Errno 256] No more mirrors to try.
libtool-ltdl-devel-1.5.22-7.el5_4.i386: failure: CentOS/libtool-ltdl-devel-1.5.22-7.el5_4.i386.rpm from base: [Errno 256] No more mirrors to try.
curl-devel-7.15.5-16.el5_9.i386: failure: RPMS/curl-devel-7.15.5-16.el5_9.i386.rpm from updates: [Errno 256] No more mirrors to try.
libmcrypt-devel-2.5.8-4.el5.centos.x86_64: failure: RPMS/libmcrypt-devel-2.5.8-4.el5.centos.x86_64.rpm from extras: [Errno 256] No more mirrors to try.
libmcrypt-2.5.8-4.el5.centos.x86_64: failure: RPMS/libmcrypt-2.5.8-4.el5.centos.x86_64.rpm from extras: [Errno 256] No more mirrors to try.
libjpeg-devel-6b-37.i386: failure: CentOS/libjpeg-devel-6b-37.i386.rpm from base: [Errno 256] No more mirrors to try.
curl-7.15.5-16.el5_9.i386: failure: RPMS/curl-7.15.5-16.el5_9.i386.rpm from updates: [Errno 256] No more mirrors to try.
gd-devel-2.0.33-9.4.el5_4.2.i386: failure: CentOS/gd-devel-2.0.33-9.4.el5_4.2.i386.rpm from base: [Errno 256] No more mirrors to try.
2:libpng-1.2.10-17.el5_8.i386: failure: CentOS/libpng-1.2.10-17.el5_8.i386.rpm from base: [Errno 256] No more mirrors to try.
freetype-2.2.1-32.el5_9.1.x86_64: failure: RPMS/freetype-2.2.1-32.el5_9.1.x86_64.rpm from updates: [Errno 256] No more mirrors to try.
curl-devel-7.15.5-16.el5_9.x86_64: failure: RPMS/curl-devel-7.15.5-16.el5_9.x86_64.rpm from updates: [Errno 256] No more mirrors to try.
freetype-devel-2.2.1-32.el5_9.1.i386: failure: RPMS/freetype-devel-2.2.1-32.el5_9.1.i386.rpm from updates: [Errno 256] No more mirrors to try.
curl-7.15.5-16.el5_9.x86_64: failure: RPMS/curl-7.15.5-16.el5_9.x86_64.rpm from updates: [Errno 256] No more mirrors to try.
gd-2.0.33-9.4.el5_4.2.i386: failure: CentOS/gd-2.0.33-9.4.el5_4.2.i386.rpm from base: [Errno 256] No more mirrors to try.
libXpm-devel-3.5.5-3.x86_64: failure: CentOS/libXpm-devel-3.5.5-3.x86_64.rpm from base: [Errno 256] No more mirrors to try.
gd-2.0.33-9.4.el5_4.2.x86_64: failure: CentOS/gd-2.0.33-9.4.el5_4.2.x86_64.rpm from base: [Errno 256] No more mirrors to try.
freetype-2.2.1-32.el5_9.1.i386: failure: RPMS/freetype-2.2.1-32.el5_9.1.i386.rpm from updates: [Errno 256] No more mirrors to try.
mhash-devel-0.9.9-1.el5.rf.x86_64: failure: RPMS/mhash-devel-0.9.9-1.el5.rf.x86_64.rpm from rpmforge: [Errno 256] No more mirrors to try.
2:libpng-1.2.10-17.el5_8.x86_64: failure: CentOS/libpng-1.2.10-17.el5_8.x86_64.rpm from base: [Errno 256] No more mirrors to try.
libcap-devel-1.10-26.i386: failure: CentOS/libcap-devel-1.10-26.i386.rpm from base: [Errno 256] No more mirrors to try.
libtool-ltdl-devel-1.5.22-7.el5_4.x86_64: failure: CentOS/libtool-ltdl-devel-1.5.22-7.el5_4.x86_64.rpm from base: [Errno 256] No more mirrors to try.
libtool-ltdl-1.5.22-7.el5_4.x86_64: failure: CentOS/libtool-ltdl-1.5.22-7.el5_4.x86_64.rpm from base: [Errno 256] No more mirrors to try.
libidn-devel-0.6.5-1.1.x86_64: failure: CentOS/libidn-devel-0.6.5-1.1.x86_64.rpm from base: [Errno 256] No more mirrors to try.
2:libpng-devel-1.2.10-17.el5_8.i386: failure: CentOS/libpng-devel-1.2.10-17.el5_8.i386.rpm from base: [Errno 256] No more mirrors to try.
libXpm-3.5.5-3.i386: failure: CentOS/libXpm-3.5.5-3.i386.rpm from base: [Errno 256] No more mirrors to try.
libgcc-4.1.2-54.el5.i386: failure: CentOS/libgcc-4.1.2-54.el5.i386.rpm from base: [Errno 256] No more mirrors to try.
gd-devel-2.0.33-9.4.el5_4.2.x86_64: failure: CentOS/gd-devel-2.0.33-9.4.el5_4.2.x86_64.rpm from base: [Errno 256] No more mirrors to try.
8 May 16:07:41 ntpdate[4058]: step time server 218.30.114.84 offset 2.018276 sec
httpd: unrecognized service
mysqld: unrecognized service
error reading information on service httpd: No such file or directory
error reading information on service mysqld: No such file or directory
installing mysql...
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking how to create a ustar tar archive... gnutar
checking for style of include used by make... GNU
checking for gcc... no
checking for cc... no
checking for cl.exe... configure: error: in `/home/lanmp/mysql-5.1.63':
configure: error: no acceptable C compiler found in $PATH
See `config.log' for more details.
no
Preparing... package rpmforge-release-0.5.2-2.el5.rf.x86_64 is already installed
Loaded plugins: fastestmirror
* base: mirrors.btte.net
* extras: mirrors.btte.net
* rpmforge: mirror.oscc.org.my
* updates: mirrors.btte.net
no
這個(gè)又是什么原因,我問(wèn)主機(jī)服務(wù)商說(shuō)也不管裝Lnmp環(huán)境
第一個(gè)是域名解析的問(wèn)題,第二個(gè)可能是網(wǎng)絡(luò)原因
本帖最后由 YYQTYZH 于 2013-5-14 01:36 編輯
回復(fù) 1# admin
   你好,管理員!我安裝的是apache的LAMP安裝包,由于我的云主機(jī)是共享ip的,空間商不提供空余的端口,問(wèn)一下能不能提供一個(gè)類(lèi)似這個(gè)帖子http://m.gps-cemuyi.cn/bbs/thread-1508-1-1.html中的方法來(lái)訪(fǎng)問(wèn)wdcp的管理面板,而不是通過(guò)某一個(gè)端口。
all is OK
Stopping httpd:                                            [  OK  ]
Starting httpd:                                            [  OK  ]
Stopping pure-config.pl:
Starting pure-config.pl: Running: /usr/sbin/pure-ftpd --daemonize -S21 -A -c50 -B -C8 -D -E -fftp -H -I15 -L10000:8 -m4 -s -U133:022 -u100 -k99 -Z -lunix -p20000:20500 -lmysql:/www/wdlinux/etc/pureftpd-mysql.conf
                configuration ,wdcp install is finshed
                visit http://ip:8080
                more infomation please visit http://m.gps-cemuyi.cn
終于安裝完了
老大合適跟新  5.3   或者  5.4的
安裝老是,不能完美結(jié)束!
嗯 真不錯(cuò) 支持……
秀依林楓
wget http://down.wdlinux.cn/in/lanmp_wdcp_ins.sh  下載不了哦。。
WDlinux
下載不了提示什么
金幣是如何來(lái)的?
我是許諾
內(nèi)存的確得優(yōu)化一下了
wdlinux.cn
eAccelerator沒(méi)有用最新版本,是不是沒(méi)有人更新了,我看apc加速的靠譜點(diǎn)吧,還有人更新
RPM包安裝是什么意思老大,我用源碼編譯安裝安裝完,再用rpm包安裝,暈,沖突了
發(fā)現(xiàn)一個(gè)問(wèn)題:
運(yùn)行 sh in.sh 時(shí)會(huì)報(bào)2個(gè)異常:
in.sh: 3: [: !=: unexpected operator
in.sh: 8: [: ==: unexpected operator
Select Install
        1 apache + php + mysql + zend + eAccelerator + pureftpd + phpmyadmin
        2 nginx + php + mysql + zend + eAccelerator + pureftpd + phpmyadmin
        3 nginx + apache + php + mysql + zend + eAccelerator + pureftpd + phpmyadmin
        4 install all service
        5 don't install is now
運(yùn)行 shi in.sh uninstall時(shí),不會(huì)卸載,也會(huì)報(bào)這2個(gè)異常。
真心很好用啊,很方便管理,之前做虛擬主機(jī)都是自己手動(dòng)配置的,累死了~~!  支持了,希望能更好的走下去。。。
