[求助] mysql升級為5.5后的奇怪問題
CentOs6.2 64bit,裝了lamp,因為用到的一個軟件必須要php 5.3以上版本,所以根據(jù)論壇里的方法開始折騰。
先升級到了mysql 5.5,升級成功,phpmyadmin中提示server版本是5.5.27,client版本是5.1。然后升級php 5.3,不管怎么折騰都不成功。翻遍論壇,有個朋友說一定要先升級mysql然后再升級php5.3。幸好做了快照,再次折騰。
先升級php 5.3,裝了一些要用到的externsion。然后升級mysql 5.5,當(dāng)然,肯定不成功的,幸好論壇里關(guān)于php和mysql升級的帖子翻得都爛了,修改/www/wdlinux/init.d/mysqld文件如下:
        basedir = /www/wdlinux/mysql
        datadir= /www/wdlinux/mysql/var
mysqld啟動起來了。但還有問題:
phpmyadmin里面顯示server和client都是5.1版本,但是服務(wù)器上用mysqld -V查看顯示:
        mysqld  Ver 5.5.27 for Linux on x86_64 (Source distribution)
查看/www/wdlinux/mysql-5.5.27/var里面的err文件,顯示:
        130524 15:07:40 mysqld_safe Starting mysqld daemon with databases from /www/wdlinux/mysql/var
        130524 15:07:40 InnoDB: The InnoDB memory heap is disabled
        130524 15:07:40 InnoDB: Mutexes and rw_locks use GCC atomic builtins
        130524 15:07:40 InnoDB: Compressed tables use zlib 1.2.3
        130524 15:07:40 InnoDB: Initializing buffer pool, size = 128.0M
        130524 15:07:40 InnoDB: Completed initialization of buffer pool
        130524 15:07:40 InnoDB: highest supported file format is Barracuda.
        130524 15:07:40  InnoDB: Waiting for the background threads to start
        130524 15:07:41 InnoDB: 1.1.8 started; log sequence number 1595675
        130524 14:58:22 [Note] Server hostname (bind-address): '0.0.0.0'; port: 3306
        130524 14:58:22 [Note]   - '0.0.0.0' resolves to '0.0.0.0';
        130524 14:58:22 [Note] Server socket created on IP: '0.0.0.0'.
        130524 15:07:41 [ERROR] Missing system table mysql.proxies_priv; please run mysql_upgrade to create it
        130524 15:07:41 [Note] Event Scheduler: Loaded 0 events
        130524 15:07:41 [Note] /www/wdlinux/mysql/bin/mysqld: ready for connections.
        Version: '5.5.27'  socket: '/tmp/mysql.sock'  port: 3306  Source distribution
修改/www/wdlinux/etc/my.cnf文件,在[mysqld]下面加入
        bind-address    = 127.0.0.1
再執(zhí)行
        mysql_upgrade -u root -p
都是OK。重啟mysqld,查看err文件:
        130524 15:16:47 mysqld_safe Starting mysqld daemon with databases from /www/wdlinux/mysql/var
        130524 15:16:47 InnoDB: The InnoDB memory heap is disabled
        130524 15:16:47 InnoDB: Mutexes and rw_locks use GCC atomic builtins
        130524 15:16:47 InnoDB: Compressed tables use zlib 1.2.3
        130524 15:16:47 InnoDB: Initializing buffer pool, size = 128.0M
        130524 15:16:47 InnoDB: Completed initialization of buffer pool
        130524 15:16:47 InnoDB: highest supported file format is Barracuda.
        130524 15:16:47  InnoDB: Waiting for the background threads to start
        130524 15:16:48 InnoDB: 1.1.8 started; log sequence number 1595685
        130524 15:16:48 [Note] Server hostname (bind-address): '127.0.0.1'; port: 3306
        130524 15:16:48 [Note]   - '127.0.0.1' resolves to '127.0.0.1';
        130524 15:16:48 [Note] Server socket created on IP: '127.0.0.1'.
        130524 15:16:48 [Note] Event Scheduler: Loaded 0 events
        130524 15:16:48 [Note] /www/wdlinux/mysql/bin/mysqld: ready for connections.
進(jìn)入phpmyadmin,顯示還是5.1版本。這是怎么回事?
這里的前面,明明說了,先升級mysql,再升級php
怎么后面,就升級php,再升級mysql了?
什么邏輯?
回admin:是我翻論壇問google大半天弄得頭昏腦漲,再加上年紀(jì)有點大,寫錯了。應(yīng)該是“先升級php后升級mysql”。其實你要是有耐心看看就明白是個筆誤了。是這個帖子http://m.gps-cemuyi.cn/bbs/thread-3737-2-1.html里ngibo1278網(wǎng)友說的:
發(fā)表于 2012-10-10 00:09 | 只看該作者
折騰了兩個夜晚,終于成功了,謝謝老大的耐心指導(dǎo)!
正確的升級流程是:先安裝WDCP面板,隨后安裝cmake,一定要安裝這個文件,隨后升級php,隨后升級相關(guān)的php緩存插件,隨后升級mysql,這樣才完全升級成功。之前出錯可能是cmake文件的版本問題,開始用的高版本,后來換到低版本,再先升級php,這樣才行;先升級mysql,后面安裝php要調(diào)整很多地方。
不過你當(dāng)時也不太相信ngibo1278的方法:
回復(fù) 29# ngibo1278
升級腳本里有自動安裝cmake的
按理,先升級mysql,再升級php會更好的,如果同時也要升級mysql的話
php調(diào)整很多地方,比如呢?
這幾天翻論壇的感覺有兩點:
1、菜鳥太多,毫無疑問我也是。其實這是肯定的,都是高手都能自己搞定上來問個P啊,對吧?
2、admin的脾氣有點點大。當(dāng)然你是高手,瞧不起菜鳥是有資格的,對有些菜鳥不肯翻帖子我也有點看不過去。不過這個論壇不就是為了大家解決使用中碰到的問題的嗎?
呵呵,今天喝了點小酒,有點直截了當(dāng),得罪得罪
哇靠!莫名其妙地好了。
下午在單位又是重啟web,又是重啟mysql,再是重啟整個服務(wù)器,折騰了不知多少次,phpmyadmin里面就是顯示mysql是5.1.63,剛剛頂撞了admin一下再翻帖子,才注意到wdcp后臺有獨立的apache,php。嘗試不通過wdcp而是直接連接到后臺phpmyadmin,里面竟然已經(jīng)顯示mysql 5.5.27了,再到wdcp里面去看也是5.5.27了。當(dāng)然肯定不是因為我先直接登錄了phpmyadmin,反正現(xiàn)在好了。不過估計admin又要讓我去看簽名了哈哈
補充一下,以我的經(jīng)歷證明了ngibo1278說的是對的,要升級的話一定要“先升級php再升級mysql”
我沒什么脾氣,也不敢說是什么高手,也理解每一次新人,因為我也是這樣過來的
不過我確實沒有耐心,也看不慣一些,教程,文檔,FAQ都不看,就說這說那的人
對于這個問題,我還是堅持我認(rèn)為正確的操作方法是,先mysql,后php
當(dāng)然,只要能正常,這個順序也不是必須
后來仔細(xì)想想,這個問題不一定是wdcp或者服務(wù)器哪里有什么不對,最可能的原因是我的瀏覽器緩存,我只是刷新了頁面,沒有清空重來。
