[求助] msyql 突然無法鏈接,現(xiàn)在通過命令行和控制面板都無法啟動啟動
突然無法啟動了,通過控制面板和命令行都無法啟動,下面是啟動的時候報的錯。
如有知曉情況的大佬幫解答一下。!
  1. 191221 22:34:04 [Note] Plugin 'FEDERATED' is disabled.
  2. 191221 22:34:04 InnoDB: The InnoDB memory heap is disabled
  3. 191221 22:34:04 InnoDB: Mutexes and rw_locks use GCC atomic builtins
  4. 191221 22:34:04 InnoDB: Compressed tables use zlib 1.2.11
  5. 191221 22:34:04 InnoDB: Initializing buffer pool, size = 128.0M
  6. 191221 22:34:04 InnoDB: Completed initialization of buffer pool
  7. 191221 22:34:04 InnoDB: highest supported file format is Barracuda.
  8. InnoDB: The log sequence number in ibdata files does not match
  9. InnoDB: the log sequence number in the ib_logfiles!
  10. 191221 22:34:04  InnoDB: Database was not shut down normally!
  11. InnoDB: Starting crash recovery.
  12. InnoDB: Reading tablespace information from the .ibd files...
  13. InnoDB: Restoring possible half-written data pages from the doublewrite
  14. InnoDB: buffer...
  15. 191221 22:34:04  InnoDB: Waiting for the background threads to start
  16. 191221 22:34:05 InnoDB: 5.5.62 started; log sequence number 32450410
  17. 191221 22:34:05 [Note] Server hostname (bind-address): '0.0.0.0'; port: 3306
  18. 191221 22:34:05 [Note]   - '0.0.0.0' resolves to '0.0.0.0';
  19. 191221 22:34:05 [Note] Server socket created on IP: '0.0.0.0'.
  20. 191221 22:34:05 [ERROR] Fatal error: Can't open and lock privilege tables: Table 'mysql.host' doesn't exist
復制代碼
做過什么改動或設置
回復 2# admin
   沒有
開魯呀
回復 2# admin
   大佬 網(wǎng)上說只能重裝 是真的假的哦   。重裝了 里面數(shù)據(jù)還能用嗎?
開魯呀
奇怪的是,wdcp的控制面板能進  難道wdcp的數(shù)據(jù)庫不是用的mysql?
開魯呀
不能沉下去呀
開魯呀
