[求助] 求助。。!大神幫幫忙吧。!nginx 502 Bad Gateway
nginx 502 Bad Gateway 一直用著好好的 突然崩潰了 就一直502 Bad Gateway了下面是 PHP-FPM LOG里面的錯誤信息 百度 谷歌 都搜過了 辦法都使了 還是沒修好!求大神幫忙。。!
an 23 04:26:04.317644 [WARNING] fpm_stdio_child_said(), line 167: child 13744 (pool default) said into stderr: "Jan 23 04:26:03.380153 [ERROR] fpm_unix_init_child(), line 215: setuid(1000) failed: Resource temporarily unavailable (11)"
Jan 23 04:26:04.317660 [WARNING] fpm_stdio_child_said(), line 167: child 13744 (pool default) said into stderr: "Jan 23 04:26:03.380360 [ERROR] fpm_child_init(), line 140: child failed to initialize (pool default)", pipe is closed
Jan 23 04:26:04.318348 [NOTICE] fpm_children_make(), line 352: child 14107 (pool default) started
Jan 23 04:26:04.318492 [WARNING] fpm_children_bury(), line 215: child 13745 (pool default) exited with code 255 after 0.939823 seconds from start
Jan 23 04:26:04.318518 [WARNING] fpm_stdio_child_said(), line 167: child 13745 (pool default) said into stderr: "Jan 23 04:26:03.380097 [ERROR] fpm_unix_init_child(), line 215: setuid(1000) failed: Resource temporarily unavailable (11)"
Jan 23 04:26:04.318532 [WARNING] fpm_stdio_child_said(), line 167: child 13745 (pool default) said into stderr: "Jan 23 04:26:03.380422 [ERROR] fpm_child_init(), line 140: child failed to initialize (pool default)", pipe is closed
Jan 23 04:26:04.319188 [NOTICE] fpm_children_make(), line 352: child 14108 (pool default) started
Jan 23 04:26:04.319354 [WARNING] fpm_children_bury(), line 215: child 13746 (pool default) exited with code 255 after 0.934405 seconds from start
人生如是!
知道的朋友幫幫忙啊 別光看啊 求大家?guī)兔Π?/td>
人生如是!
http://dadloveu.blog.51cto.com/715500/766214  自己看
樓上的帖子之前就試過了 沒起作用
人生如是!
在php.ini里,eaccelerator配置項一定要放在Zend Optimizer配置之前,否則也可能引起502 Bad Gateway
檢查下資源是不是被占用了,受到攻擊也是這樣的
找到問題了 是XCACHE的事 只要一設(shè)置 xcache.size= 任何一個數(shù)值 就502 設(shè)置成0就沒事了 不知道怎么回事。。。
eaccelerator配置項是在Zend Optimizer配置之前。
[xcache]
xcache.shm_scheme = "mmap"
xcache.size = 128M
xcache.count = 4
xcache.slots = 64K
xcache.ttl = 600
xcache.gc_interval = 600
人生如是!
我擦  我啥也沒動上午好好的  中午出現(xiàn)和你一樣的問題
