˜Ë(bi¨¡o)î}: [ÇóÖú] ÖØÐ¾Ž×gPHP5.3.27 make test•r(sh¨ª)°l(f¨¡)ÉúÒÔÏÂåe(cu¨°)Õ`£¬ÈçºÎ½â›Q°¡£¿ [´òÓ¡±¾í“]
×÷Õß: quyu    •r(sh¨ª)ég: 2014-6-23 15:10     ˜Ë(bi¨¡o)î}: ÖØÐ¾Ž×gPHP5.3.27 make test•r(sh¨ª)°l(f¨¡)ÉúÒÔÏÂåe(cu¨°)Õ`£¬ÈçºÎ½â›Q°¡£¿
FAILED TEST SUMMARY
Bug #43073 (TrueType bounding box is wrong for angle<>0) freetype < 2.4.10 [ext/gd/tests/bug43073.phpt]
Bug #48801 (Problem with imagettfbbox) freetype < 2.4.10 [ext/gd/tests/bug48801.phpt]
Bug #31141 (properties declared in the class extending MySQLi are not available) [ext/mysqli/tests/bug31141.phpt]
Bug #49936 (crash with ftp stream in php_stream_context_get_option()) [ext/standard/tests/streams/bug49936.phpt]
