無法連接mysql,請(qǐng)檢查mysql是否已啟動(dòng)及用戶密碼是否設(shè)置正確!:
yux82
本帖最后由 yux82 于 2014-6-26 10:32 編輯
早上想升級(jí)下phpmyadmin 到4.0 版本,一重啟就出現(xiàn)這個(gè)錯(cuò)誤了
wdcp 版本是2.5.10
日志如下,管理員能幫忙看看什么情況么
140626 9:49:53 [ERROR] Aborting
140626 9:49:53 [Note] /www/wdlinux/mysql/libexec/mysqld: Shutdown complete
140626 09:49:53 mysqld_safe mysqld from pid file /www/wdlinux/mysql/var/MyServer.pid ended
140626 09:50:29 mysqld_safe Starting mysqld daemon with databases from /www/wdlinux/mysql-5.1.63/var
/www/wdlinux/mysql-5.1.63/libexec/mysqld: Can't find file: './mysql/plugin.frm' (errno: 13)
140626 9:50:30 [ERROR] Can't open the mysql.plugin table. Please run mysql_upgrade to create it.
140626 9:50:30 [ERROR] /www/wdlinux/mysql-5.1.63/libexec/mysqld: unknown variable 'innodb_additional_mem_pool_size=16M'
140626 9:50:30 [ERROR] Aborting
140626 9:50:30 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: Shutdown complete
140626 09:50:30 mysqld_safe mysqld from pid file /www/wdlinux/mysql-5.1.63/var/MyServer.pid ended
140626 10:06:45 mysqld_safe Starting mysqld daemon with databases from /www/wdlinux/mysql-5.1.63/var
140626 10:06:45 [ERROR] Can't open the mysql.plugin table. Please run mysql_upgrade to create it.
140626 10:06:45 [ERROR] /www/wdlinux/mysql-5.1.63/libexec/mysqld: unknown variable 'innodb_additional_mem_pool_size=16M'
140626 10:06:45 [ERROR] Aborting
140626 10:06:45 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: Shutdown complete
140626 10:06:45 mysqld_safe mysqld from pid file /www/wdlinux/mysql-5.1.63/var/MyServer.pid ended
140626 10:12:04 mysqld_safe Starting mysqld daemon with databases from /www/wdlinux/mysql-5.1.63/var
140626 10:12:04 [ERROR] Can't open the mysql.plugin table. Please run mysql_upgrade to create it.
140626 10:12:04 [ERROR] /www/wdlinux/mysql-5.1.63/libexec/mysqld: unknown variable 'innodb_additional_mem_pool_size=16M'
140626 10:12:04 [ERROR] Aborting
140626 10:12:04 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: Shutdown complete
140626 10:12:04 mysqld_safe mysqld from pid file /www/wdlinux/mysql-5.1.63/var/MyServer.pid ended
yux82
用了網(wǎng)站上的 sh 修復(fù)功能也沒有效果,直接出個(gè)err 錯(cuò)誤就過去了
kideny
以前也遇到過這個(gè)問題,mysql占內(nèi)存太大,直接掛掉了。
換個(gè)數(shù)據(jù)引擎!
hifi
kideny 發(fā)表于 2014-7-1 14:19
老大詳細(xì)說下,怎么換啊
昆特斯二世
回復(fù)
4#
hifi
RDS
