標(biāo)題: [求助] 求救:怎么調(diào)整硬盤大小? [打印本頁]
作者: yvsm    時(shí)間: 2012-7-14 00:14     標(biāo)題: 求救:怎么調(diào)整硬盤大小?
我的是VPS主機(jī),之前是20G的硬盤,后來不夠用了,又加了20G,
怎么將這個(gè)20G也掛載到/www 下面呀?
求救~~~
  1. #fdisk -l
  2. Disk /dev/sda: 21.4 GB, 21474836480 bytes
  3. 255 heads, 63 sectors/track, 2610 cylinders
  4. Units = cylinders of 16065 * 512 = 8225280 bytes
  5.    Device Boot      Start         End      Blocks   Id  System
  6. /dev/sda1   *           1          13      104391   83  Linux
  7. /dev/sda2              14        2610    20860402+  8e  Linux LVM
  8. Disk /dev/sdb: 21.4 GB, 21474836480 bytes
  9. 255 heads, 63 sectors/track, 2610 cylinders
  10. Units = cylinders of 16065 * 512 = 8225280 bytes
  11.    Device Boot      Start         End      Blocks   Id  System
  12. /dev/sdb1               1        2610    20964793+   5  Extended
作者: admin    時(shí)間: 2012-7-14 10:22
http://m.gps-cemuyi.cn/bbs/thread-2781-1-1.html
