標(biāo)題: [求助] RPM包安裝后,nginx啟動(dòng)切換失敗 502 Bad Gateway [打印本頁(yè)]
作者: vincent828    時(shí)間: 2012-7-24 08:17     標(biāo)題: RPM包安裝后,nginx啟動(dòng)切換失敗 502 Bad Gateway
本帖最后由 vincent828 于 2012-7-24 08:20 編輯
php網(wǎng)站打不開,html可以。
nginx を起動(dòng)中:                                            [  OK  ]
       php-cgi <file> [args...]
  -a               Run interactively
  -b <address:port>|<port> Bind Path for external FASTCGI Server mode
  -C               Do not chdir to the script's directory
  -n               No php.ini file will be used
  -d foo[=bar]     Define INI entry foo with value 'bar'
  -e               Generate extended information for debugger/profiler
  -f <file>        Parse <file>.  Implies `-q'
  -h               This help
  -i               PHP information
  -l               Syntax check only (lint)
  -m               Show compiled in modules
  -q               Quiet-mode.  Suppress HTTP Header output.
  -s               Display colour syntax highlighted source.
  -v               Version number
  -w               Display source with stripped comments and whitespace.
  -z <file>        Load Zend extension <file>.
  -T <count>       Measure execution time of script repeated <count> times.
................................... failed
作者: admin    時(shí)間: 2012-7-24 09:34
對(duì)應(yīng)版塊,提供系統(tǒng)版本位數(shù),wdcp版本,lamp,lnmp,lnamp是哪個(gè)環(huán)境,rpm或編譯安裝
作者: vincent828    時(shí)間: 2012-7-24 09:52
嗯。不好意思。重新發(fā)了。
http://m.gps-cemuyi.cn/bbs/thread-2978-1-1.html
