標(biāo)題: [求助] 求助無法啟動數(shù)據(jù)庫 [打印本頁]
作者: helwo    時間: 2012-8-8 20:31     標(biāo)題: 求助無法啟動數(shù)據(jù)庫
起因:因為經(jīng)常發(fā)文出現(xiàn)504 于是我就按照
在Nginx.conf里加上【  給我加分!加在client_max_body_size 8m; 之后  】:
        fastcgi_connect_timeout 3000s;
        fastcgi_send_timeout 3000s;
        fastcgi_read_timeout 3000s;
        fastcgi_buffer_size 64k;
        fastcgi_buffers 8 128k;
        fastcgi_busy_buffers_size 256k;
        fastcgi_temp_file_write_size 256k;
        fastcgi_intercept_errors on;
修改后還是不行
http://m.gps-cemuyi.cn/bbs/viewthread.php?tid=2194&highlight=504
再按照這個帖子修改
修改后不行。我就想刪除原來的,重啟web服務(wù)和數(shù)據(jù)庫。web啟動好了,啟動數(shù)據(jù)庫就無法啟動了。這時按照下面的方法再次修改。還是不行。
[root@310174 data]# service mysqld restart
ERROR! MySQL manager or server PID file could not be found!
今天晚上突然無法啟動數(shù)據(jù)庫,
sed -i '/skip-innodb/d' /www/wdlinux/etc/my.cnf
這個命令用過
作者: helwo    時間: 2012-8-8 21:32
管理員在不。非常著急,感謝了
作者: helwo    時間: 2012-8-8 21:36
120701 20:09:44 mysqld_safe Starting mysqld daemon with databases from /www/wdlinux/mysql-5.1.63/var
120701 20:09:44 [Note] Event Scheduler: Loaded 0 events
120701 20:09:44 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: ready for connections.
Version: '5.1.63'  socket: '/tmp/mysql.sock'  port: 3306  Source distribution
120701 20:27:55 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: Normal shutdown
120701 20:27:55 [Note] Event Scheduler: Purging the queue. 0 events
120701 20:27:55 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: Shutdown complete
120701 20:27:55 mysqld_safe mysqld from pid file /www/wdlinux/mysql-5.1.63/var/310174.techd.pid ended
120701 20:27:57 mysqld_safe Starting mysqld daemon with databases from /www/wdlinux/mysql-5.1.63/var
120701 20:27:57 [Note] Event Scheduler: Loaded 0 events
120701 20:27:57 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: ready for connections.
120705 10:10:06 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: Normal shutdown
120705 10:10:06 [Note] Event Scheduler: Purging the queue. 0 events
120705 10:10:06 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: Shutdown complete
120705 10:10:06 mysqld_safe mysqld from pid file /www/wdlinux/mysql-5.1.63/var/310174.techd.pid ended
120705 10:10:46 mysqld_safe Starting mysqld daemon with databases from /www/wdlinux/mysql-5.1.63/var
120705 10:10:47 [Note] Event Scheduler: Loaded 0 events
120705 10:10:47 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: ready for connections.
120808 19:40:02 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: Normal shutdown
120808 19:40:02 [Note] Event Scheduler: Purging the queue. 0 events
120808 19:40:02 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: Shutdown complete
120808 19:40:04 mysqld_safe Starting mysqld daemon with databases from /www/wdlinux/mysql-5.1.63/var
作者: helwo    時間: 2012-8-8 21:38
120808 20:56:37 mysqld_safe Starting mysqld daemon with databases from /www/wdlinux/mysql-5.1.63/var
120808 20:56:37 [ERROR] Can't start server: Bind on TCP/IP port: Address already in use
120808 20:56:37 [ERROR] Do you already have another mysqld server running on port: 3306 ?
120808 20:56:37 [ERROR] Aborting
120808 20:56:37 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: Shutdown complete
120808 20:56:37 mysqld_safe mysqld from pid file /www/wdlinux/mysql-5.1.63/var/310174.techd.pid ended
120808 20:56:40 mysqld_safe Starting mysqld daemon with databases from /www/wdlinux/mysql-5.1.63/var
120808 20:56:40 [ERROR] Can't start server: Bind on TCP/IP port: Address already in use
120808 20:56:40 [ERROR] Do you already have another mysqld server running on port: 3306 ?
120808 20:56:40 [ERROR] Aborting
120808 20:56:40 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: Shutdown complete
120808 20:56:40 mysqld_safe mysqld from pid file /www/wdlinux/mysql-5.1.63/var/310174.techd.pid ended
120808 21:11:07 mysqld_safe Starting mysqld daemon with databases from /www/wdlinux/mysql-5.1.63/var
120808 21:11:07 [ERROR] Can't start server: Bind on TCP/IP port: Address already in use
120808 21:11:07 [ERROR] Do you already have another mysqld server running on port: 3306 ?
120808 21:11:07 [ERROR] Aborting
120808 21:11:07 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: Shutdown complete
120808 21:11:07 mysqld_safe mysqld from pid file /www/wdlinux/mysql-5.1.63/var/310174.techd.pid ended
作者: admin    時間: 2012-8-8 22:51
這個數(shù)據(jù)庫,沒看出有什么問題
做這哪些操作或更改,一個個恢復(fù)原來的來嘗試就可以
