標(biāo)題: [求助] lanmp隔斷時間報502/504錯誤 [打印本頁]
作者: mingwd    時間: 2012-9-28 23:01     標(biāo)題: lanmp隔斷時間報502/504錯誤
使用lanmp隔段時間報502/504錯誤,相隔的時間都很近,而且基本都是在凌晨的時候出現(xiàn)這個問題的,這個是我記錄下來日志這個是一臺服務(wù)器的
reboot apacheFri Sep  7 03:45:01 CST 2012
reboot apache
Tue Sep 18 03:30:01 CST 2012
reboot apache
Fri Sep 28 03:30:02 CST 2012
reboot apache
第二臺的
Sat Sep 15 03:30:01 CST 2012
reboot apache
Thu Sep 27 03:46:35 CST 2012
reboot apache
第三臺的
Mon Sep 10 03:45:01 CST 2012
reboot apache
Tue Sep 18 03:45:02 CST 2012
reboot apache
Wed Sep 26 03:30:02 CST 2012
reboot apache
這個是重啟apache的記錄,時間非常奇怪.
作者: mingwd    時間: 2012-9-28 23:52
本帖最后由 mingwd 于 2012-9-28 23:54 編輯
  1. [Wed Sep 26 03:20:03 2012] [notice] SIGHUP received.  Attempting to restart
  2. [Wed Sep 26 03:20:03 2012] [notice] Apache/2.2.22 (Unix) PHP/5.2.17p1 configured -- resuming normal operations
  3. [Wed Sep 26 03:20:03 2012] [notice] SIGHUP received.  Attempting to restart
  4. [Wed Sep 26 03:20:03 2012] [notice] Apache/2.2.22 (Unix) PHP/5.2.17p1 configured -- resuming normal operations
  5. [Wed Sep 26 03:20:04 2012] [notice] SIGHUP received.  Attempting to restart
  6. [Wed Sep 26 03:20:04 2012] [notice] Apache/2.2.22 (Unix) PHP/5.2.17p1 configured -- resuming normal operations
  7. [Wed Sep 26 03:20:04 2012] [notice] SIGHUP received.  Attempting to restart
  8. [Wed Sep 26 03:20:04 2012] [notice] Apache/2.2.22 (Unix) PHP/5.2.17p1 configured -- resuming normal operations
  9. [Wed Sep 26 03:20:04 2012] [notice] SIGHUP received.  Attempting to restart
  10. [Wed Sep 26 03:20:04 2012] [notice] Apache/2.2.22 (Unix) PHP/5.2.17p1 configured -- resuming normal operations
  11. [Wed Sep 26 03:20:04 2012] [notice] SIGHUP received.  Attempting to restart
  12. [Wed Sep 26 03:20:04 2012] [notice] Apache/2.2.22 (Unix) PHP/5.2.17p1 configured -- resuming normal operations
  13. [Wed Sep 26 03:20:04 2012] [notice] SIGHUP received.  Attempting to restart
  14. [Wed Sep 26 03:20:05 2012] [notice] Apache/2.2.22 (Unix) PHP/5.2.17p1 configured -- resuming normal operations
  15. [Wed Sep 26 03:20:05 2012] [notice] SIGHUP received.  Attempting to restart
  16. [Wed Sep 26 03:20:05 2012] [notice] Apache/2.2.22 (Unix) PHP/5.2.17p1 configured -- resuming normal operations
  17. [Wed Sep 26 03:20:05 2012] [notice] SIGHUP received.  Attempting to restart
  18. [Wed Sep 26 03:20:05 2012] [notice] Apache/2.2.22 (Unix) PHP/5.2.17p1 configured -- resuming normal operations
  19. [Wed Sep 26 03:20:05 2012] [notice] SIGHUP received.  Attempting to restart
  20. [Wed Sep 26 03:20:05 2012] [notice] Apache/2.2.22 (Unix) PHP/5.2.17p1 configured -- resuming normal operations[Wed Sep 26 03:20:19 2012] [notice] seg fault or similar nasty error detected in the parent process
查看apache錯誤,里面顯示的是這個
作者: admin    時間: 2012-9-29 09:36
你上面的重起apache,是因為502/504了才重起apache
還是本身定期重起apache的功能?
如果是在重起apache的過程中,502/504,那是正常的
作者: mingwd    時間: 2012-9-29 10:22
回復(fù) 3# admin
   這個是在出現(xiàn)502/504后才重啟的,因為用的crond +curl 隔段時間檢測網(wǎng)站狀態(tài),檢查到502/504才重啟apache.
作者: admin    時間: 2012-9-29 10:50
看那個時間,都集中在3點多,是不是這個時間段有什么特別的東西在運行?
作者: mingwd    時間: 2012-9-29 11:12
回復(fù) 5# admin
   應(yīng)該沒有, 因為這個我都是裝完系統(tǒng)后就裝了LNAMP,其他都沒動。計劃任務(wù)里也沒有。
作者: admin    時間: 2012-9-29 11:59
那真有點怪呀,幾臺機都在差不多的同一時間里這樣
