按照這個http://m.gps-cemuyi.cn/bbs/thread-38462-1-1.html 操作的
Stopping nginx: [ OK ]
Shutting down php_fpm . done
Starting nginx: [ OK ]
php-cgi <file> [args...]
-a Run interactively
-C Do not chdir to the script's directory
-n No php.ini file will be used
-d foo[=bar] Define INI entry foo with value 'bar'
-e Generate extended information for debugger/profiler
-f <file> Parse <file>. Implies `-q'
-h This help
-i PHP information
-l Syntax check only (lint)
-m Show compiled in modules
-q Quiet-mode. Suppress HTTP Header output.
-s Display colour syntax highlighted source.
-v Version number
-w Display source with stripped comments and whitespace.
-z <file> Load Zend extension <file>.
................................... failed作者: 強追猛進 時間: 2015-9-27 00:47
