標題: [求助] worepress安裝插件Problem with the SSL CA cert (path? access rights?) [打印本頁]
作者: recommend    時間: 2015-12-2 21:32     標題: worepress安裝插件Problem with the SSL CA cert (path? access rights?)
wordpress安裝插件時出現(xiàn)這個問題:Problem with the SSL CA cert (path? access rights?)
這個問題怎么解決?以前都沒出現(xiàn)過這種問題的
作者: admin    時間: 2015-12-3 15:52
這個插件要用到https?
