標題:
各位大神,Mysql 老是自動卡機過一會自動重啟,錯誤日志如下!
l9ong
2015-12-28 21:36
標題:
151228 20:22:56 mysqld_safe Number of processes running now: 0
151228 20:22:56 mysqld_safe mysqld restarted
151228 20:22:56 [Warning] '--skip-locking' is deprecated and will be removed in a future release. Please use '--skip-external-locking' instead.
151228 20:23:04 [Note] Event Scheduler: Loaded 0 events
151228 20:23:04 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: ready for connections.
Version: '5.1.63' socket: '/tmp/mysql.sock' port: 3306 Source distribution
151228 20:26:24 mysqld_safe Number of processes running now: 0
151228 20:26:24 mysqld_safe mysqld restarted
151228 20:26:33 [Warning] '--skip-locking' is deprecated and will be removed in a future release. Please use '--skip-external-locking' instead.
151228 20:26:35 [Note] Event Scheduler: Loaded 0 events
151228 20:26:35 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: ready for connections.
151228 20:29:20 mysqld_safe A mysqld process already exists
151228 20:33:04 mysqld_safe Number of processes running now: 0
151228 20:33:07 mysqld_safe mysqld restarted
151228 20:33:09 [Warning] '--skip-locking' is deprecated and will be removed in a future release. Please use '--skip-external-locking' instead.
151228 20:33:09 [Note] Event Scheduler: Loaded 0 events
151228 20:33:09 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: ready for connections.
151228 20:36:38 mysqld_safe Number of processes running now: 0
151228 20:36:38 mysqld_safe mysqld restarted
151228 20:36:39 [Warning] '--skip-locking' is deprecated and will be removed in a future release. Please use '--skip-external-locking' instead.
151228 20:36:43 [Note] Event Scheduler: Loaded 0 events
151228 20:36:43 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: ready for connections.
151228 20:44:09 mysqld_safe Number of processes running now: 0
151228 20:44:13 mysqld_safe mysqld restarted
151228 20:44:21 [Warning] '--skip-locking' is deprecated and will be removed in a future release. Please use '--skip-external-locking' instead.
151228 20:44:21 [Note] Event Scheduler: Loaded 0 events
151228 20:44:21 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: ready for connections.
151228 20:46:16 mysqld_safe Number of processes running now: 0
151228 20:46:16 mysqld_safe mysqld restarted
151228 20:46:23 [Warning] '--skip-locking' is deprecated and will be removed in a future release. Please use '--skip-external-locking' instead.
151228 20:46:24 [Note] Event Scheduler: Loaded 0 events
151228 20:46:24 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: ready for connections.
151228 20:46:40 mysqld_safe A mysqld process already exists
151228 20:49:09 mysqld_safe A mysqld process already exists
151228 20:56:44 mysqld_safe A mysqld process already exists
151228 21:04:17 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: Normal shutdown
151228 21:04:17 [Note] Event Scheduler: Purging the queue. 0 events
151228 21:04:19 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: Shutdown complete
151228 21:04:19 mysqld_safe mysqld from pid file /www/wdlinux/mysql-5.1.63/var/iZ25d2up3riZ.pid ended
151228 21:04:20 mysqld_safe Starting mysqld daemon with databases from /www/wdlinux/mysql-5.1.63/var
151228 21:04:20 [Note] Event Scheduler: Loaded 0 events
151228 21:04:20 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: ready for connections.
151228 21:04:33 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: Normal shutdown
151228 21:04:33 [Note] Event Scheduler: Purging the queue. 0 events
151228 21:04:35 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: Shutdown complete
151228 21:04:35 mysqld_safe mysqld from pid file /www/wdlinux/mysql-5.1.63/var/iZ25d2up3riZ.pid ended
151228 21:04:35 mysqld_safe Starting mysqld daemon with databases from /www/wdlinux/mysql-5.1.63/var
151228 21:04:35 [Note] Event Scheduler: Loaded 0 events
151228 21:04:35 [Note] /www/wdlinux/mysql-5.1.63/libexec/mysqld: ready for connections.
151228 21:20:24 mysqld_safe A mysqld process already exists
復制代碼
這是怎么回事呀~~
