標(biāo)題: [求助] PHP 報(bào)錯(cuò),幫忙看看那 [打印本頁(yè)]
作者: mywaft    時(shí)間: 2013-2-22 14:54     標(biāo)題: PHP 報(bào)錯(cuò),幫忙看看那
Warning: realpath() [function.realpath]: open_basedir restriction in effect. File(/www/wdlinux/apache_php-5.2.17/lib/php/extensions/no-debug-zts-20060613) is not within the allowed path(s): (/www/web/88261:/tmp) in /www/web/88261/public_html/install/install.php on line 34
Warning: file_exists() [function.file-exists]: open_basedir restriction in effect. File(/www/web/ioncube/ioncube_loader_lin_5.2.so) is not within the allowed path(s): (/www/web/88261:/tmp) in /www/web/88261/public_html/install/install.php on line 34
Warning: file_exists() [function.file-exists]: open_basedir restriction in effect. File(/www/ioncube/ioncube_loader_lin_5.2.so) is not within the allowed path(s): (/www/web/88261:/tmp) in /www/web/88261/public_html/install/install.php on line 34
Site error: the file /www/web/88261/public_html/install/install.php requires the ionCube PHP Loader ioncube_loader_lin_5.2.so to be installed by the site administrator.
作者: admin    時(shí)間: 2013-2-22 19:28
在站點(diǎn)編譯里,取消目錄限制試試
作者: mywaft    時(shí)間: 2013-2-25 10:05
Site error: the file install/install.php requires the ionCube PHP Loader ioncube_loader_lin_5.2.so to be installed by the site administrator.
作者: admin    時(shí)間: 2013-2-25 10:45
沒(méi)加載 ionCube
