160608 14:16:28 mysqld_safe mysqld from pid file /www/wdlinux/mysql/var/iZ940ofh866Z.pid ended
160608 14:26:49 mysqld_safe Starting mysqld daemon with databases from /www/wdlinux/mysql/var
160608 14:26:49 [Warning] 'THREAD_CONCURRENCY' is deprecated and will be removed in a future release.
160608 14:26:49 [Note] /www/wdlinux/mysql-5.5.44/bin/mysqld (mysqld 5.5.44) starting as process 14044 ...
160608 14:26:49 InnoDB: The InnoDB memory heap is disabled
160608 14:26:49 InnoDB: Mutexes and rw_locks use GCC atomic builtins
160608 14:26:49 InnoDB: Compressed tables use zlib 1.2.3
160608 14:26:49 InnoDB: Initializing buffer pool, size = 128.0M
InnoDB: mmap(137363456 bytes) failed; errno 12
160608 14:26:49 InnoDB: Completed initialization of buffer pool
160608 14:26:49 InnoDB: Fatal error: cannot allocate memory for the buffer pool
160608 14:26:49 [ERROR] Plugin 'InnoDB' init function returned error.
160608 14:26:49 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
160608 14:26:49 [ERROR] Unknown/unsupported storage engine: InnoDB
160608 14:26:49 [ERROR] Aborting
160608 14:26:49 [Note] /www/wdlinux/mysql-5.5.44/bin/mysqld: Shutdown complete
歡迎光臨 WDlinux官方論壇 (http://m.gps-cemuyi.cn/bbs/) | Powered by Discuz! 7.2 |
