標(biāo)題: [BUG反饋] 新裝wdcp3重啟后pureftpd無法啟動(dòng) [打印本頁(yè)]
作者: linboy    時(shí)間: 2016-7-11 15:47     標(biāo)題: 新裝wdcp3重啟后pureftpd無法啟動(dòng)
手動(dòng)啟動(dòng)提示Starting pureftpd (via systemctl):  Job for pureftpd.service failed because the control process exited with error code. See "systemctl status pureftpd.service" and "journalctl -xe" for details.
作者: wanzhende    時(shí)間: 2016-7-11 17:03
使用systemctl status pureftpd.service命令看看錯(cuò)誤信息
作者: iemail520    時(shí)間: 2016-7-12 13:32
[root@MyCloudServer tools]# systemctl status pureftpd.service
● pureftpd.service - SYSV: Pure-FTPd is an FTP server daemon based upon Troll-FTPd
   Loaded: loaded (/etc/rc.d/init.d/pureftpd)
   Active: failed (Result: exit-code) since Tue 2016-07-12 11:50:24 CST; 1h 29min ago
     Docs: man:systemd-sysv-generator(8)
Jul 12 11:50:24 MyCloudServer systemd[1]: Starting SYSV: Pure-FTPd is an FTP server daemon base......
Jul 12 11:50:24 MyCloudServer pureftpd[28166]: Starting pure-ftpd:
Jul 12 11:50:24 MyCloudServer systemd[1]: pureftpd.service: control process exited, code=exited...252
Jul 12 11:50:24 MyCloudServer systemd[1]: Failed to start SYSV: Pure-FTPd is an FTP server daem...Pd.
Jul 12 11:50:24 MyCloudServer systemd[1]: Unit pureftpd.service entered failed state.
Jul 12 11:50:24 MyCloudServer systemd[1]: pureftpd.service failed.
Hint: Some lines were ellipsized, use -l to show in full.
作者: linboy    時(shí)間: 2016-7-14 09:58
   Active: failed (Result: exit-code) since 四 2016-07-14 09:48:01 CST; 38s ago
  Process: 32482 ExecStart=/etc/rc.d/init.d/pureftpd start (code=exited, status=127)
7月 14 09:48:01 localhost.localdomain systemd[1]: Starting SYSV: Pure-FTPd is an FTP server daemon based upon Troll-FTPd...
7月 14 09:48:01 localhost.localdomain pureftpd[32482]: Starting pure-ftpd:
7月 14 09:48:01 localhost.localdomain systemd[1]: pureftpd.service: control process exited, code=exited status=127
7月 14 09:48:01 localhost.localdomain systemd[1]: Failed to start SYSV: Pure-FTPd is an FTP server daemon based upon Troll-FTPd.
7月 14 09:48:01 localhost.localdomain systemd[1]: Unit pureftpd.service entered failed state.
7月 14 09:48:01 localhost.localdomain systemd[1]: pureftpd.service failed.
作者: linboy    時(shí)間: 2016-7-14 10:03
回復(fù) 2# wanzhende
作者: hanfei    時(shí)間: 2017-6-13 21:12
我的也一樣遇到了   重新啟動(dòng)服務(wù)器后 就沒有 pureftp 服務(wù)了
