標(biāo)題: [求助] mysql升級(jí)5.5后數(shù)據(jù)庫(kù)無法連接phpMyAdmin錯(cuò)誤2002 [打印本頁]
作者: crossdasky    時(shí)間: 2017-2-20 10:00     標(biāo)題: mysql升級(jí)5.5后數(shù)據(jù)庫(kù)無法連接phpMyAdmin錯(cuò)誤2002
登錄phpMyAdmin報(bào)錯(cuò):
phpMyAdmin - Error
#2002 - The server is not responding (or the local MySQL server's socket is not correctly configured)
wordpress報(bào)錯(cuò):
Error establishing a database connection
按照論壇教程(http://m.gps-cemuyi.cn/bbs/viewthread.php?tid=5461 )操作的,并且嘗試了老大在http://m.gps-cemuyi.cn/bbs/viewth ... ghlight=mysql%2B5.5 說的修改localhost為127.0.01還是同樣的錯(cuò)誤。
請(qǐng)問這個(gè)是什么情況?謝謝
還有我的 /www/wdlinux/init.d/mysqld 文件是不是有多余的東西,在ssh嘗試用vi修改的時(shí)候總是保存不了。http://pan.baidu.com/share/link?shareid=141086264&uk=1671249803
超字?jǐn)?shù)發(fā)布了,為了能預(yù)覽把后綴改成txt了。
作者: 向上的蔥子    時(shí)間: 2017-2-20 10:57
看下是否啟用了MySQL的root賬戶,再看下密碼是否正確
作者: crossdasky    時(shí)間: 2017-2-22 08:49
回復(fù) 2# 向上的蔥子
看了下好像mysql運(yùn)行有問題這個(gè)怎么解決?謝謝
  1. [root@iZm5eaj9b52jsu50vyaxhmZ ~]# service mysqld start
  2. env: /etc/init.d/mysqld: No such file or directory
  3. [root@iZm5eaj9b52jsu50vyaxhmZ ~]# service mysqld startservice mysqld start
  4. env: /etc/init.d/mysqld: No such file or directory
  5. [root@iZm5eaj9b52jsu50vyaxhmZ ~]#
  6. [root@iZm5eaj9b52jsu50vyaxhmZ ~]# service mysqld starts
  7. env: /etc/init.d/mysqld: No such file or directory
  8. [root@iZm5eaj9b52jsu50vyaxhmZ ~]# find mysqld
  9. find: `mysqld': No such file or directory
  10. [root@iZm5eaj9b52jsu50vyaxhmZ ~]# cd /etc/init.d
  11. [root@iZm5eaj9b52jsu50vyaxhmZ init.d]# find mysqld
  12. mysqld
  13. [root@iZm5eaj9b52jsu50vyaxhmZ init.d]# service mysqld start
  14. env: /etc/init.d/mysqld: No such file or directory
  15. [root@iZm5eaj9b52jsu50vyaxhmZ init.d]# mysqladmin restart
  16. mysqladmin: connect to server at 'localhost' failed
  17. error: 'Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2)'
  18. Check that mysqld is running and that the socket: '/tmp/mysql.sock' exists!
  19. [root@iZm5eaj9b52jsu50vyaxhmZ init.d]# /ect/init.d/mysql restart
  20. -bash: /ect/init.d/mysql: No such file or directory
  21. [root@iZm5eaj9b52jsu50vyaxhmZ init.d]# cd
  22. [root@iZm5eaj9b52jsu50vyaxhmZ ~]#
  23. [root@iZm5eaj9b52jsu50vyaxhmZ ~]# mysqladmin restart
  24. mysqladmin: connect to server at 'localhost' failed
  25. error: 'Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2)'
  26. Check that mysqld is running and that the socket: '/tmp/mysql.sock' exists!
  27. [root@iZm5eaj9b52jsu50vyaxhmZ ~]#
作者: crossdasky    時(shí)間: 2017-2-22 16:52
本想著如果用另一臺(tái)vps重復(fù)步驟看看哪里出錯(cuò)了,但現(xiàn)在v3安裝直接是高版本了?
作者: 向上的蔥子    時(shí)間: 2017-2-22 17:12
mysql配置文件里面指定user為root
作者: crossdasky    時(shí)間: 2017-2-26 14:11
回復(fù) 5# 向上的蔥子
請(qǐng)問這個(gè)要如何設(shè)置? 謝謝
作者: 嗨嗨    時(shí)間: 2017-3-4 08:57
我的也是這個(gè)問題怎么解決?
