標題: [求助] 安裝最新版一鍵包,NGINX服務(wù)啟動失敗 [打印本頁]
作者: star0312    時間: 2017-3-6 20:18     標題: 安裝最新版一鍵包,NGINX服務(wù)啟動失敗
[root@localhost ~]# systemctl status nginxd
● nginxd.service - SYSV: Nginx is an HTTP(S) server, HTTP(S) reverse proxy and IMAP/POP3 proxy server
   Loaded: loaded (/etc/rc.d/init.d/nginxd; bad; vendor preset: disabled)
   Active: failed (Result: exit-code) since Mon 2017-03-06 19:57:22 CST; 10min ago
     Docs: man:systemd-sysv-generator(8)
Mar 06 19:57:22 localhost.localdomain systemd[1]: Starting SYSV: Nginx is an HTTP(S) server, HTTP(S) reverse proxy and IMAP/POP3 proxy server...
Mar 06 19:57:22 localhost.localdomain nginxd[50583]: Starting nginx: nginx: [emerg] getpwnam("www") failed in /www/wdlinux/nginx/conf/nginx.conf:4
Mar 06 19:57:22 localhost.localdomain nginxd[50583]: [FAILED]
Mar 06 19:57:22 localhost.localdomain systemd[1]: nginxd.service: control process exited, code=exited status=1
Mar 06 19:57:22 localhost.localdomain systemd[1]: Failed to start SYSV: Nginx is an HTTP(S) server, HTTP(S) reverse proxy and IMAP/POP3 proxy server.
Mar 06 19:57:22 localhost.localdomain systemd[1]: Unit nginxd.service entered failed state.
Mar 06 19:57:22 localhost.localdomain systemd[1]: nginxd.service failed.
不知道什么原因啊,安裝了好幾次,都出現(xiàn)這個提示。
作者: star0312    時間: 2017-3-6 20:20
安裝環(huán)境是:Centos7.2
作者: cn5m    時間: 2017-3-11 16:42
支持。。支持。。
作者: 冬至雨    時間: 2017-6-23 09:54
后來怎么解決的?我也是7.2
作者: langwai    時間: 2017-7-6 15:36
先升級一下系統(tǒng),再安裝看看
作者: da39165197    時間: 2017-7-20 12:00
沒有建立名叫“www”的用戶名和組,解決辦法可以用現(xiàn)有的用戶和組,也可以手動建立名叫“www”的用戶和組
