標(biāo)題: [求助] wdcp PHP5.2 升5.3時(shí)出錯(cuò)了 [打印本頁(yè)]
作者: soewl    時(shí)間: 2017-7-22 11:40     標(biāo)題: wdcp PHP5.2 升5.3時(shí)出錯(cuò)了
checking size of long... (cached) 8
checking for int32_t... yes
checking for uint32_t... yes
checking for strtoll... yes
checking for atoll... yes
checking which regex library to use... php
checking libxml2 install dir... /usr
checking for xml2-config path...
configure: error: xml2-config not found. Please check your libxml2 installation.
configure err
在線等
