標題: [求助] 安裝php錯誤 [打印本頁]
作者: xjsxiao2004    時間: 2017-10-23 18:04     標題: 安裝php錯誤
  1. checking for stdlib.h... (cached) yes
  2. checking for strtoll... yes
  3. checking for atoll... yes
  4. checking for strftime... (cached) yes
  5. checking which regex library to use... php
  6. checking whether to enable LIBXML support... yes
  7. checking libxml2 install dir... /usr
  8. checking for xml2-config path...
  9. configure: error: xml2-config not found. Please check your libxml2 installation.
  10. make: *** No targets specified and no makefile found.  Stop.
  11. x86_64
  12. wdOS 1.0
  13. -----------------
  14. ----Install Error: 5.6.30 -----------
  15. [root@wdOS ~]# yum install -y icu libicu libicu-devel
  16. Loaded plugins: fastestmirror
  17. Loading mirror speeds from cached hostfile
  18. http://mirrors.163.com/centos/5/os/x86_64/repodata/repomd.xml: [Errno 14] HTTP E           rror 404: Not Found
  19. Trying other mirror.
  20. Error: Cannot retrieve repository metadata (repomd.xml) for repository: base. Pl           ease verify its path and try again
  21. [root@wdOS ~]#
復制代碼
這個要怎么破
