標(biāo)題: [求助] Zend Optimizer not installed [打印本頁]
作者: wujika    時間: 2013-6-6 18:10     標(biāo)題: Zend Optimizer not installed
之前都快用1年了 都是好好  今天突然提示這個了  其他的站都沒問題 就這個管理后臺打不開 提示這個了
http://203.98.159.226:8080/
Wdlinux Control Panel Zend Optimizer not installed
This file was encoded by the Zend Guard. In order to run it, please install the Zend Optimizer (available without charge), version 3.0.0 or later. Seeing this message instead of the website you expected?
This means that this webserver is not configured correctly. In order to view this website properly, please contact the website's system administrator/webmaster with the following message:
The component "Zend Optimizer" is not installed on the Web Server and therefore cannot service encoded files. Please download and install the Zend Optimizer (available without charge) on the Web Server.
Note: Zend Technologies cannot resolve issues related to this message appearing on websites not belonging to Zend Technologies. What is the Zend Optimizer?
The Zend Optimizer is one of the most popular PHP plugins for performance-improvement, and has been available without charge, since the early days of PHP 4. It improves performance by scanning PHP's intermediate code and passing it through multiple Optimization Passes to replace inefficient code patterns with more efficient code blocks. The replaced code blocks perform exactly the same operations as the original code, only faster.
In addition to improving performance, the Zend Optimizer also enables PHP to transparently load files encoded by the Zend Guard.
The Zend Optimizer is a free product available for download from Zend Technologies. Zend Technologies also developed the PHP scripting engine, known as the Zend Engine
作者: wujika    時間: 2013-6-6 18:13
管理員可幫忙看看嗎
作者: wujika    時間: 2013-6-6 19:07
管理員 在哪里去了 泡妞去了么 呵呵
作者: admin    時間: 2013-6-6 20:46
哪個版本的
作者: wujika    時間: 2013-6-6 23:23
現(xiàn)在也進不去后臺 一看不到什么版本  應(yīng)該升級到最新版本了的
作者: wujika    時間: 2013-6-6 23:24
方便的話 我給你IP和密碼你幫我看下吧 高了一天了 實在對linux不熟悉
作者: wujika    時間: 2013-6-7 15:44
管理員我等你哦
