標(biāo)題: [提問] 開啟HTTPS只支持TLS1.2不支持1.1和1.0 [打印本頁]
作者: lele8060    時間: 2017-12-1 21:12     標(biāo)題: 開啟HTTPS只支持TLS1.2不支持1.1和1.0
  1. SSLEngine on
  2. SSLCertificateFile conf/cert/xxx.com.crt
  3. SSLCertificateKeyFile conf/cert/xxx.com.key
  4. SSLCertificateChainFile conf/cert/xxx.com_root_bundle.crt
  5. SSLProtocol TLSv1 TLSv1.1 TLSv1.2
  6. SSLCipherSuite EECDH+CHACHA20:EECDH+AES128:RSA+AES128:EECDH+AES256:RSA+AES256:EECDH+3DES:RSA+3DES:!MD5
  7. DocumentRoot /www/web/xxx/public_html
用ssllabs.com測試結(jié)果
Protocols
TLS 1.3No
TLS 1.2Yes
TLS 1.1No
TLS 1.0No
SSL 3No
SSL 2No
作者: lele8060    時間: 2018-5-11 16:17
終于解決了
https://serverfault.com/questions/513961/how-to-disable-tls-1-1-1-2-in-apache
First of all, you must identify what is the default vhost for port 443 in your server (the first SSL vhost loaded by Apache) and edit it's configuration file. Most users have an ssl.conf file in their servers, with a vhost for port 443 configured there. As the name of this file begins with "s", it will load before the vhosts configured in vhosts.conf (which begins with "v"). So, check if this is your case (the answer is "yes" for virtually everyone) and change the protocols in that file. That's enough!
作者: 乘風(fēng)    時間: 2019-1-18 23:45
請問具體是怎么解決的,我試了幾次,還是不行,新手請教一下
作者: 乘風(fēng)    時間: 2019-1-18 23:47
回復(fù) 2# lele8060
   可以具體說一下你是怎么解決的嗎
作者: 乘風(fēng)    時間: 2019-1-19 10:38
回復(fù) 2# lele8060
<VirtualHost *:443>
SSLEngine on
SSLCertificateFile conf/cert/x.star.com.crt
SSLCertificateKeyFile conf/cert/x.star.com.key
SSLCertificateChainFile conf/cert/bundle_x.star.com.crt
#SSLProtocol +SSLv3 +TLSv1 +TLSv1.1 +TLSv1.2 -SSLv2 -SSLv3 -TLSv1 -TLSv1.1
SSLCipherSuite ECDHE-RSA-AES128-GCM-SHA256:ECDHE:ECDH:AES:HIGH:!NULL:!aNULL:!MD5:!ADH:!RC4
#SSLProtocol all -SSLv2 -SSLv3
#SSLCipherSuite HIGH:!RC4:!MD5:!aNULL:!eNULL:!NULL:!DH:!EDH:!EXP:+MEDIUM
#SSLHonorCipherOrder on
