請(qǐng)問WDCP3.2.21如何設(shè)置Nginx支持TP5的pathinfo?
[打印本頁(yè)]
Locked
我在網(wǎng)上找了一些方法修改對(duì)應(yīng)域名的.conf但是沒有辦法完成 請(qǐng)問如何可以實(shí)現(xiàn)呢?
Locked
求大神們幫幫解決。。
hyqlhy
同求同求,現(xiàn)在的配置文件是錯(cuò)的,獲取不到PATHINFO
hyqlhy
我找到了一種辦法,配置文件如下:
server {
listen 80;
root /www/web/xxxx/public_html;
include /www/wdlinux/wdcp/rewrite/robelf_nginx.conf;
server_name xxxx.com www.xxxx.com;
index index.html index.php index.htm;
error_page 400 /errpage/400.html;
error_page 403 /errpage/403.html;
error_page 404 /errpage/404.html;
error_page 503 /errpage/503.html;
location ~ \.php {
fastcgi_pass unix:/tmp/php-56-cgi.sock;
fastcgi_index index.php;
include fcgi.conf;
set $real_script_name $fastcgi_script_name;
if ($fastcgi_script_name ~ "^(.+?\.php)(/.+)$") {
set $real_script_name $1;
set $path_info $2;
fastcgi_param SCRIPT_FILENAME $document_root$real_script_name;
fastcgi_param SCRIPT_NAME $real_script_name;
fastcgi_param PATH_INFO $path_info;
location ~ /\.ht {
deny all;
location / {
try_files $uri $uri/ /?$args;
Locked
回復(fù)
4#
hyqlhy
感謝,我先嘗試一下!
Miker
安裝完成需要配置Nginx相關(guān)文件重新啟動(dòng)服務(wù)器即可的
Locked
回復(fù)
6#
Miker
你這當(dāng)什么都沒說啊
jiangyouhong
回復(fù)
1#
Locked
你好,打開wdcp面板,找到-文件管理-點(diǎn)擊nginx,然后修改對(duì)應(yīng)站點(diǎn)的nginx配置為:
location ~ \.php(.*)$ {
fastcgi_param SCRIPT_FILENAME $DOCUMENT_ROOT$fastcgi_script_name;
fastcgi_param PATH_INFO $2;
include fcgi.conf;
set $path_info "";
if ($fastcgi_script_name ~ "^(.+\.php)(/.+)$") {
set $path_info $2;
jiangyouhong
回復(fù)
8#
jiangyouhong
當(dāng)然了,要從啟一下web服務(wù)
風(fēng)過意濃
/www/wdlinux/wdcp/rewrite/robelf_nginx.conf; 這個(gè)文件呢?
