標題: [求助] 服務(wù)器突然報500 錯誤,下面是NGINX日志和PHP 日志 [打印本頁]
作者: z4231    時間: 2018-11-17 13:22     標題: 服務(wù)器突然報500 錯誤,下面是NGINX日志和PHP 日志
  1. 2018/11/16 21:36:17 [notice] 15338#0: signal process started
  2. 2018/11/16 21:36:17 [notice] 1383#0: signal 15 (SIGTERM) received, exiting
  3. 2018/11/16 21:36:17 [notice] 1385#0: exiting
  4. 2018/11/16 21:36:17 [notice] 1386#0: exiting
  5. 2018/11/16 21:36:17 [notice] 1385#0: exit
  6. 2018/11/16 21:36:17 [notice] 1386#0: exit
  7. 2018/11/16 21:36:17 [notice] 1384#0: exiting
  8. 2018/11/16 21:36:17 [notice] 1384#0: exit
  9. 2018/11/16 21:36:17 [notice] 1383#0: signal 17 (SIGCHLD) received
  10. 2018/11/16 21:36:17 [notice] 1383#0: worker process 1385 exited with code 0
  11. 2018/11/16 21:36:17 [notice] 1383#0: worker process 1386 exited with code 0
  12. 2018/11/16 21:36:17 [notice] 1383#0: signal 29 (SIGIO) received
  13. 2018/11/16 21:36:17 [notice] 1383#0: signal 17 (SIGCHLD) received
  14. 2018/11/16 21:36:17 [notice] 1383#0: signal 17 (SIGCHLD) received
  15. 2018/11/16 21:36:17 [notice] 1383#0: worker process 1384 exited with code 0
  16. 2018/11/16 21:36:17 [notice] 1383#0: exit
  17. 2018/11/16 21:37:16 [notice] 1139#0: using the "epoll" event method
  18. 2018/11/16 21:37:16 [notice] 1139#0: nginx/1.8.1
  19. 2018/11/16 21:37:16 [notice] 1139#0: built by gcc 4.8.5 20150623 (Red Hat 4.8.5-28) (GCC)
  20. 2018/11/16 21:37:16 [notice] 1139#0: OS: Linux 3.10.0-693.el7.x86_64
  21. 2018/11/16 21:37:16 [notice] 1139#0: getrlimit(RLIMIT_NOFILE): 1024:4096
  22. 2018/11/16 21:37:16 [notice] 1184#0: start worker processes
  23. 2018/11/16 21:37:16 [notice] 1184#0: start worker process 1187
  24. 2018/11/16 21:37:16 [notice] 1184#0: start worker process 1188
  25. 2018/11/16 21:37:16 [notice] 1184#0: start worker process 1189
