標題:
msyql 突然無法鏈接,現(xiàn)在通過命令行和控制面板都無法啟動啟動
datena
2019-12-22 22:54
標題:
突然無法啟動了,通過控制面板和命令行都無法啟動,下面是啟動的時候報的錯。
如有知曉情況的大佬幫解答一下!!
191221 22:34:04 [Note] Plugin 'FEDERATED' is disabled.
191221 22:34:04 InnoDB: The InnoDB memory heap is disabled
191221 22:34:04 InnoDB: Mutexes and rw_locks use GCC atomic builtins
191221 22:34:04 InnoDB: Compressed tables use zlib 1.2.11
191221 22:34:04 InnoDB: Initializing buffer pool, size = 128.0M
191221 22:34:04 InnoDB: Completed initialization of buffer pool
191221 22:34:04 InnoDB: highest supported file format is Barracuda.
InnoDB: The log sequence number in ibdata files does not match
InnoDB: the log sequence number in the ib_logfiles!
191221 22:34:04 InnoDB: Database was not shut down normally!
InnoDB: Starting crash recovery.
InnoDB: Reading tablespace information from the .ibd files...
InnoDB: Restoring possible half-written data pages from the doublewrite
InnoDB: buffer...
191221 22:34:04 InnoDB: Waiting for the background threads to start
191221 22:34:05 InnoDB: 5.5.62 started; log sequence number 32450410
191221 22:34:05 [Note] Server hostname (bind-address): '0.0.0.0'; port: 3306
191221 22:34:05 [Note] - '0.0.0.0' resolves to '0.0.0.0';
191221 22:34:05 [Note] Server socket created on IP: '0.0.0.0'.
191221 22:34:05 [ERROR] Fatal error: Can't open and lock privilege tables: Table 'mysql.host' doesn't exist
2019-12-23 11:59
做過什么改動或設(shè)置
datena
2019-12-23 20:06
回復(fù)
2#
沒有
datena
2019-12-23 21:18
回復(fù)
2#
大佬 網(wǎng)上說只能重裝 是真的假的哦 。重裝了 里面數(shù)據(jù)還能用嗎?
datena
2019-12-23 21:29
奇怪的是,wdcp的控制面板能進 難道wdcp的數(shù)據(jù)庫不是用的mysql?
datena
2019-12-24 08:44
不能沉下去呀
