標(biāo)題: [求助] nginx+apache模式下不能啟用GZIP壓縮 [打印本頁]
作者: seaking    時(shí)間: 2013-12-7 01:12     標(biāo)題: nginx+apache模式下不能啟用GZIP壓縮
后臺(tái) 已經(jīng)開啟gzip
gzip監(jiān)測的網(wǎng)站檢查 沒有開啟
ssh:curl -I www.xxx.com--compressed
測試結(jié)果:
HTTP/1.0 200 OK
Server: nginx/1.0.12
Date: Fri, 06 Dec 2013 17:02:18 GMT
Content-Type: text/html; charset=UTF-8
Vary: Accept-Encoding
X-Powered-By: PHP/5.2.17p1
Set-Cookie: frontend=40b83b2e6984db5292c613adc87744cf; expires=Fri, 06-Dec-2013 18:02:17 GMT; path=/; domain=www.xxxxx.com; HttpOnly
Expires: Thu, 19 Nov 1981 08:52:00 GMT
Cache-Control: no-store, no-cache, must-revalidate, post-check=0, pre-check=0
Pragma: no-cache
X-Cache: MISS from WT263CDN-10371
X-Cache-Lookup: MISS from WT263CDN-10371:80
X-Cache: MISS from WT263CDN-2974
X-Cache-Lookup: MISS from WT263CDN-2974:80
X-Cache: MISS from WT263CDN-18309
X-Cache-Lookup: MISS from WT263CDN-18309:80
Via: 1.0 WT263CDN-10371 (squid/3.0.STABLE20), 1.0 WT263CDN-2974 (squid/3.0.STABLE20), 1.0 WT263CDN-18309 (squid/3.0.STABLE20)
Connection: close
作者: tiajslwm    時(shí)間: 2018-11-6 15:01
我也是 沒找到啊
localhost:~ junhyung$ curl -I xxx --compressed
HTTP/1.1 200 OK
Server: nginx/1.8.1
Date: Tue, 06 Nov 2018 07:09:26 GMT
Content-Length: 1008
Connection: keep-alive
Last-Modified: Tue, 06 Nov 2018 06:10:02 GMT
ETag: "3f0-579f8da2f84e2"
Accept-Ranges: bytes
