1X升級(jí)時(shí),不成功
tianhuqiu
1X升級(jí)時(shí),不成功
還是虛擬機(jī),系統(tǒng)為wdlinux_lnmp_32,只升級(jí)wdcp 1X為2.1版本
出現(xiàn)很多錯(cuò)誤代碼,沒有升級(jí)成功,部分代碼如下:
util.c: In function ‘a(chǎn)p_find_token’:
util.c:1462: error: ‘test_char_table’ undeclared (first use in this function)
util.c:1462: error: (Each undeclared identifier is reported only once
util.c:1462: error: for each function it appears in.)
util.c:1462: error: ‘T_HTTP_TOKEN_STOP’ undeclared (first use in this function)
util.c: In function ‘a(chǎn)p_escape_shell_cmd’:
util.c:1526: error: ‘test_char_table’ undeclared (first use in this function)
util.c:1526: error: ‘T_ESCAPE_SHELL_CMD’ undeclared (first use in this function)
util.c: In function ‘a(chǎn)p_escape_path_segment’:
util.c:1711: error: ‘test_char_table’ undeclared (first use in this function)
util.c:1711: error: ‘T_ESCAPE_PATH_SEGMENT’ undeclared (first use in this function)
util.c: In function ‘a(chǎn)p_os_escape_path’:
util.c:1740: error: ‘test_char_table’ undeclared (first use in this function)
util.c:1740: error: ‘T_OS_ESCAPE_PATH’ undeclared (first use in this function)
util.c: In function ‘a(chǎn)p_escape_logitem’:
util.c:1811: error: ‘test_char_table’ undeclared (first use in this function)
util.c:1811: error: ‘T_ESCAPE_LOGITEM’ undeclared (first use in this function)
util.c: In function ‘a(chǎn)p_escape_errorlog_item’:
util.c:1864: error: ‘test_char_table’ undeclared (first use in this function)
util.c:1864: error: ‘T_ESCAPE_LOGITEM’ undeclared (first use in this function)
make[2]: *** [util.lo] Error 1
make[2]: Leaving directory `/mnt/usb/lanmp_last/lanmp/httpd-2.0.64/server'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/mnt/usb/lanmp_last/lanmp/httpd-2.0.64/server'
make: *** [all-recursive] Error 1
----Install Error: wdapache make err -----------
是不是升級(jí)時(shí)要停止某些服務(wù)?請(qǐng)指點(diǎn),謝謝。
VM還是其它虛擬機(jī)?確定是wdlinux_lnmp_32嗎
tianhuqiu
回復(fù)
2#
VM
確定是那個(gè)版本
