回復(fù) 1# admin
老大 我安裝好了
但是怎么無法聯(lián)機(jī)數(shù)據(jù)庫(kù)啊
我哭了 ······················
make[2]: Leaving directory `/tmp/httpd-2.2.22/modules/mappers'
make[2]: Entering directory `/tmp/httpd-2.2.22/modules'
make[2]: Leaving directory `/tmp/httpd-2.2.22/modules'
make[1]: Leaving directory `/tmp/httpd-2.2.22/modules'
Making install in support
make[1]: Entering directory `/tmp/httpd-2.2.22/support'
make[2]: Entering directory `/tmp/httpd-2.2.22/support'
make[2]: Leaving directory `/tmp/httpd-2.2.22/support'
make[1]: Leaving directory `/tmp/httpd-2.2.22/support'
make[1]: Entering directory `/tmp/httpd-2.2.22'
Installing configuration files
[PRESERVING EXISTING HTDOCS SUBDIR: /www/wdlinux/httpd-2.2.22/htdocs]
[PRESERVING EXISTING ERROR SUBDIR: /www/wdlinux/httpd-2.2.22/error]
[PRESERVING EXISTING ICONS SUBDIR: /www/wdlinux/httpd-2.2.22/icons]
[PRESERVING EXISTING CGI SUBDIR: /www/wdlinux/httpd-2.2.22/cgi-bin]
Installing header files
Installing build system files
Installing man pages and online manual
make[1]: Leaving directory `/tmp/httpd-2.2.22'
Starting httpd:                                            [  OK  ]
httpd ssl install is OK
已經(jīng)安裝  但是不知道可以不?
老大啊    終于找到這個(gè)問題了  我找了好幾天了啊
先占位置
安裝過程
Build complete.
Installing PHP SAPI module:       cgi
Installing PHP CGI binary: /www/wdlinux/nginx_php-5.2.17/bin/
Installing FPM config:            /www/wdlinux/etc/php-fpm.conf
                                  (installing as php-fpm.conf.default)
Installing init.d script:         /www/wdlinux/nginx_php-5.2.17/sbin/php-fpm
Installing PHP CLI binary:        /www/wdlinux/nginx_php-5.2.17/bin/
Installing PHP CLI man page:      /www/wdlinux/nginx_php-5.2.17/man/man1/
Installing build environment:     /www/wdlinux/nginx_php-5.2.17/lib/php/build/
Installing header files:          /www/wdlinux/nginx_php-5.2.17/include/php/
Installing helper programs:       /www/wdlinux/nginx_php-5.2.17/bin/
  program: phpize
  program: php-config
Installing man pages:             /www/wdlinux/nginx_php-5.2.17/man/man1/
  page: phpize.1
  page: php-config.1
Installing PEAR environment:      /www/wdlinux/nginx_php-5.2.17/lib/php/
[PEAR] Archive_Tar    - already installed: 1.3.7
[PEAR] Console_Getopt - already installed: 1.2.3
[PEAR] Structures_Graph- already installed: 1.0.3
[PEAR] XML_Util       - already installed: 1.2.1
[PEAR] PEAR           - already installed: 1.9.1
Wrote PEAR system config file at: /www/wdlinux/nginx_php-5.2.17/etc/pear.conf
You may want to add: /www/wdlinux/nginx_php-5.2.17/lib/php to your php.ini include_path
Installing PDO headers:          /www/wdlinux/nginx_php-5.2.17/include/php/ext/pdo/
Shutting down php_fpm . done
Starting php_fpm  done
php reinstall is OK
ye1028
如果是lnmp版的環(huán)境,則使用下面這個(gè)試試(針對(duì)默認(rèn)的php-5.2.17版本)
sh lnmp_php_ssl_5217.sh
我用的lnmp環(huán)境,安裝后,QQ登錄還是502
ye1028
回復(fù) 73# admin
   是ngnix 環(huán)境
ye1028
回復(fù) 73# admin
   一樣的,在腳本里修改成2.2.24版本即可
沒明白,麻煩大哥貼 運(yùn)行語句,      祝老大身體健康,天天身邊美女如云,鈔票數(shù)得手抽筋。。。您發(fā)了再給我們這些苦B 發(fā)福利,呵呵
ye1028
回復(fù) 1# admin
httpd 2.2.2.4 怎么解決這個(gè)問題呢?大哥
ye1028
以上是針對(duì)httpd-2.2.22版本的,如果不是這個(gè)版本的,可以改成相應(yīng)的版本號(hào)就可以
我的版本號(hào)是2.2.24 怎么改版本號(hào)啊          確實(shí)同求解釋     老大
ye1028
php reinstall is OK
安裝完后,QQ登錄 還是提示 502,環(huán)境是 lnmp
ye1028
終于找到要看的東西了,。這個(gè)必須加入問題集
我的版本號(hào)是2.2.24 怎么改版本號(hào)啊  求
unizai.com
學(xué)習(xí)了,謝謝分享
[root@IDC ~]# collect2: ld returned 1 exit status
-bash: collect2:: command not found
[root@IDC ~]# make[2]: *** [htpasswd] Error 1
-bash: make[2]:: command not found
[root@IDC ~]# make[2]: Leaving directory `/tmp/httpd-2.2.22/support'
> make[1]: *** [all-recursive] Error 1
make: *** [all-recursive] Error 1
六安論壇
