[求助] linux掛載分區(qū)成功后,安裝一鍵包時(shí)如何讓根目錄WWW大的分區(qū)中
新買(mǎi)的VPS,剛裝linux系統(tǒng),接著就是分區(qū),分區(qū)后準(zhǔn)備安裝一鍵包,F(xiàn)在遇到難以下難題。
1:新增分區(qū)80G,已掛載成功,網(wǎng)站內(nèi)容很多,所以我想把WWW放在這個(gè)的分區(qū)中,可以保證數(shù)據(jù)的安全和足夠的使用空間,沒(méi)有經(jīng)驗(yàn) 我不清楚該如何操作?
第一次操作分區(qū),按網(wǎng)上的方法進(jìn)行的
新增分區(qū)和掛載分區(qū)的教程方法:
【http://help.aliyun.com/knowledge_detail.htm?spm=5176.7114037.1996646101.11.uZqfJ4&knowledgeId=5974154&pos=6】
已分區(qū),格式化,掛載成功。
2:分區(qū)加載成功后,分區(qū)信息如下
  1. [root@localhost ~]# fdisk -l
  2. Disk /dev/xvde: 96.6 GB, 96636764160 bytes
  3. 255 heads, 56 sectors/track, 13217 cylinders
  4. Units = cylinders of 14280 * 512 = 7311360 bytes
  5. Sector size (logical/physical): 512 bytes / 512 bytes
  6. I/O size (minimum/optimal): 512 bytes / 512 bytes
  7. Disk identifier: 0x142a828a
  8.     Device Boot      Start         End      Blocks   Id  System
  9. /dev/xvde1               1       11750    83894972   83  Linux
  10. Disk /dev/xvda: 21.5 GB, 21474836480 bytes
  11. 255 heads, 63 sectors/track, 2610 cylinders
  12. Units = cylinders of 16065 * 512 = 8225280 bytes
  13. Sector size (logical/physical): 512 bytes / 512 bytes
  14. I/O size (minimum/optimal): 512 bytes / 512 bytes
  15. Disk identifier: 0x000bcfbd
  16.     Device Boot      Start         End      Blocks   Id  System
  17. /dev/xvda1   *           1          64      512000   83  Linux
  18. Partition 1 does not end on cylinder boundary.
  19. /dev/xvda2              64        2611    20458496   8e  Linux LVM
  20. Disk /dev/mapper/VolGroup-lv_root: 18.8 GB, 18832424960 bytes
  21. 255 heads, 63 sectors/track, 2289 cylinders
  22. Units = cylinders of 16065 * 512 = 8225280 bytes
  23. Sector size (logical/physical): 512 bytes / 512 bytes
  24. I/O size (minimum/optimal): 512 bytes / 512 bytes
  25. Disk identifier: 0x00000000
  26. Disk /dev/mapper/VolGroup-lv_swap: 2113 MB, 2113929216 bytes
  27. 255 heads, 63 sectors/track, 257 cylinders
  28. Units = cylinders of 16065 * 512 = 8225280 bytes
  29. Sector size (logical/physical): 512 bytes / 512 bytes
  30. I/O size (minimum/optimal): 512 bytes / 512 bytes
  31. Disk identifier: 0x00000000
3:下一步,要安裝一鍵安裝包,存放網(wǎng)站的根目錄WWW放到最大的數(shù)據(jù)盤(pán)中,請(qǐng)問(wèn)我該如何操作?
關(guān)鍵1:是安裝一鍵包【后】操作還是 安裝一鍵包【前】操作?
關(guān)鍵2:操作流程和命令或方法?
請(qǐng)教高手和好心人指導(dǎo)指教下,謝謝。
我常用的一鍵安裝包的 安裝方法【http://m.gps-cemuyi.cn/lanmp/install.html】
CentOS
把/dev/xvde1加載到www分區(qū)就可以
回復(fù) 2# lxl12happy
  在 根目錄輸入cd /www
然后直接安裝就好了。
如何實(shí)現(xiàn) www目錄 放到/dev/xvde1   ???
CentOS
