[求助] 安裝lnmp_php_ssl_5217.sh是出現(xiàn)libjpeg not found
老大您好,網(wǎng)站是discuz架設(shè)的(www.matlabsky.com),由于微博沒(méi)法轉(zhuǎn)發(fā),根據(jù)http://m.gps-cemuyi.cn/bbs/thread-3657-1-1.html教程,進(jìn)行安裝lnmp_php_ssl_5217.sh,但是最后提示了如下錯(cuò)誤信息(最后一行):
checking for curl_version_info in -lcurl... yes
checking for curl_easy_strerror in -lcurl... yes
checking for curl_multi_strerror in -lcurl... yes
checking for QDBM support... no
checking for GDBM support... no
checking for NDBM support... no
checking for Berkeley DB4 support... no
checking for Berkeley DB3 support... no
checking for Berkeley DB2 support... no
checking for DB1 support... no
checking for DBM support... no
checking for CDB support... no
checking for INI File support... no
checking for FlatFile support... no
checking whether to enable DBA interface... no
checking whether to enable dbase support... no
checking whether to enable DOM support... yes
checking for xml2-config path... (cached) /usr/bin/xml2-config
checking whether libxml build works... (cached) yes
checking whether to enable EXIF (metadata from images) support... no
checking for FrontBase SQL92 (fbsql) support... no
checking for FDF support... no
checking whether to enable input filter support... yes
checking pcre install prefix... no
checking whether to enable FTP support... yes
checking OpenSSL dir for FTP... no
checking for OpenSSL version... >= 0.9.6
checking for CRYPTO_free in -lcrypto... (cached) yes
checking for SSL_CTX_set_ssl_version in -lssl... (cached) yes
checking for fabsf... yes
checking for floorf... yes
回復(fù) 2# wulali
   謝謝,這個(gè)問(wèn)題搜索的時(shí)候沒(méi)有搜到,建議論壇開(kāi)啟全文搜索,現(xiàn)在單純的標(biāo)題搜索經(jīng)常找不到東西
