[求助] mysql升級(jí)到5.5報(bào)錯(cuò)了
本帖最后由 qq682907 于 2013-2-28 23:37 編輯
wget http://down.wdlinux.cn/in/mysql_up55.sh
sh mysql_up55.sh我是按著這個(gè)升級(jí)的 是面板安裝好后
升級(jí)的
詳細(xì)的錯(cuò)誤日志
130228 23:33:43 [Note] Server hostname (bind-address): '0.0.0.0'; port: 3306
130228 23:33:43 [Note]   - '0.0.0.0' resolves to '0.0.0.0';
130228 23:33:43 [Note] Server socket created on IP: '0.0.0.0'.
130228 23:33:43 [ERROR] Fatal error: Can't open and lock privilege tables: Table 'mysql.host' doesn't exist
130228 23:33:43 mysqld_safe mysqld from pid file /www/wdlinux/mysql-5.5.27/data/MyVPS1970.pid ended
升級(jí)后沒(méi)有var這個(gè)文件夾。。。
把這行去掉
/www/wdlinux/mysql/bin/mysqld: unknown variable 'default-character-set=utf8'  默認(rèn)配置了efault-character-set=utf8就不能啟動(dòng)了
回復(fù) 18# liumingzhij26
131102 16:21:24 mysqld_safe Starting mysqld daemon with databases from /www/wdlinux/mysql/var
131102 16:21:24 InnoDB: The InnoDB memory heap is disabled
131102 16:21:24 InnoDB: Mutexes and rw_locks use InnoDB's own implementation
131102 16:21:24 InnoDB: Compressed tables use zlib 1.2.3
131102 16:21:24 InnoDB: Initializing buffer pool, size = 128.0M
131102 16:21:24 InnoDB: Completed initialization of buffer pool
131102 16:21:24 InnoDB: highest supported file format is Barracuda.
131102 16:21:24  InnoDB: Waiting for the background threads to start
131102 16:21:25 InnoDB: 1.1.8 started; log sequence number 1589339
131102 16:21:25 [ERROR] /www/wdlinux/mysql/bin/mysqld: unknown variable 'default-character-set=utf8'
131102 16:21:25 [ERROR] Aborting
131102 16:21:25  InnoDB: Starting shutdown...
131102 16:21:26  InnoDB: Shutdown completed; log sequence number 1589339
131102 16:21:26 [Note] /www/wdlinux/mysql/bin/mysqld: Shutdown complete
131102 16:21:26 mysqld_safe mysqld from pid file /www/wdlinux/mysql/var/Centos214.pid ended
Starting MySQL.... ERROR! The server quit without updating PID file (/www/wdlinux/mysql/var/Centos214.pid).
basedir=/www/wdlinux/mysql
我都修改了這個(gè),為什么還啟動(dòng)不了,已經(jīng)重啟過(guò)了
修改的是init.d目錄下mysqld這個(gè)文件,寫少了,樓上正解
哈哈
本帖最后由 qq514408389 于 2013-4-3 11:59 編輯
回復(fù) 14# qq682907
    可以修改下/www/wdlinux/init.d/mysqld這個(gè)文件
    里面這兩行basedir=
                  datadir=
    修改如下
    然后再重新試試
回復(fù) 13# zd305
   沒(méi)升級(jí)成功
錯(cuò)誤日志如下,請(qǐng)教如何解決?
130402 20:03:37 mysqld_safe Starting mysqld daemon with databases from /www/wdlinux/mysql-5.5.27/data
/www/wdlinux/mysql-5.5.27/bin/mysqld: Table 'mysql.plugin' doesn't exist
130402 20:03:37 [ERROR] Can't open the mysql.plugin table. Please run mysql_upgrade to create it.
130402 20:03:38 InnoDB: The InnoDB memory heap is disabled
130402 20:03:38 InnoDB: Mutexes and rw_locks use GCC atomic builtins
130402 20:03:38 InnoDB: Compressed tables use zlib 1.2.3
130402 20:03:38 InnoDB: Initializing buffer pool, size = 128.0M
130402 20:03:38 InnoDB: Completed initialization of buffer pool
130402 20:03:38  InnoDB: Operating system error number 13 in a file operation.
InnoDB: The error means mysqld does not have the access rights to
InnoDB: the directory.
InnoDB: File name ./ibdata1
InnoDB: File operation call: 'create'.
InnoDB: Cannot continue operation.
130402 20:03:38 mysqld_safe mysqld from pid file /www/wdlinux/mysql-5.5.27/data/li260-147.pid ended
難得糊涂
檢查mysql是否啟動(dòng),或不能啟動(dòng)的原因,看下日志
求解決辦法?
難得糊涂
這個(gè)怎么解決 我也一樣的
回復(fù) 8# admin
   已經(jīng)發(fā)了 外出了3小時(shí) 剛剛回來(lái)
