[求助] 在安裝PDO_MYSQL 的時(shí)候提示錯(cuò)誤,跪求前輩幫幫忙 re2c 0.13.4?
Configuring for:
PHP Api Version:         20041225
Zend Module Api No:      20060613
Zend Extension Api No:   220060519
config.m4:135: warning: AC_CACHE_VAL(pdo_inc_path, ...): suspicious cache-id, must contain _cv_ to be cached
../../lib/autoconf/general.m4:1974: AC_CACHE_VAL is expanded from...
../../lib/autoconf/general.m4:1994: AC_CACHE_CHECK is expanded from...
aclocal.m4:2741: PHP_CHECK_PDO_INCLUDES is expanded from...
config.m4:135: the top level
checking for cc... cc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether cc accepts -g... yes
checking for cc option to accept ISO C89... none needed
checking how to run the C preprocessor... cc -E
checking for icc... no
checking for suncc... no
checking whether cc understands -c and -o together... yes
checking for system library directory... lib
checking if compiler supports -R... no
checking if compiler supports -Wl,-rpath,... yes
checking for PHP prefix... /www/wdlinux/apache_php-5.2.17
checking for PHP includes... -I/www/wdlinux/apache_php-5.2.17/include/php -I/www/wdlinux/apache_php-5.2.17/include/php/main -I/www/wdlinux/apache_php-5.2.17/include/php/TSRM -I/www/wdlinux/apache_php-5.2.17/include/php/Zend -I/www/wdlinux/apache_php-5.2.17/include/php/ext -I/www/wdlinux/apache_php-5.2.17/include/php/ext/date/lib
checking for PHP extension directory... /www/wdlinux/apache_php-5.2.17/lib/php/extensions/no-debug-non-zts-20060613
checking for PHP installed headers prefix... /www/wdlinux/apache_php-5.2.17/include/php
checking if debug is enabled... no
checking if zts is enabled... no
checking for re2c... no
configure: WARNING: You will need re2c 0.13.4 or later if you want to regenerate PHP parsers.
checking for gawk... gawk
checking for MySQL support for PDO... yes, shared
checking for the location of libz... no
checking for mysql_config... not found
configure: error: Cannot find MySQL header files under
太菜鳥了,什么re2c 0.13.4的 應(yīng)該怎么解決 跪求幫忙  謝謝
NIIIG.COM
