[求助] 找人開(kāi)發(fā)的DZ插件出現(xiàn)出錯(cuò)頁(yè)面,如何解決?
Discuz! Database Error
The database has encountered a problem.
Need Help?
Error messages:
  • [Type] 查詢語(yǔ)句錯(cuò)誤
  • [1064] You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'm' and suoshu_bao = '2' and is_shenhe = 1' at line 1
  • [Query] SELECT * FROM `nandubao` WHERE `suoshu_dianying_id` = '1' and danci = ''m' and suoshu_bao = '2' and is_shenhe = 1
Program messages:
  • [Line: 0059]admin.php(require)
  • [Line: 0743]source/admincp/admincp_plugins.php(include)
  • [Line: 0114]source/plugin/vgallery/admincp.inc.php(DB::query)
如何解決?
Need Help?
Error messages:
Program messages:
DISCUZ!數(shù)據(jù)庫(kù)錯(cuò)誤
數(shù)據(jù)庫(kù)遇到了問(wèn)題。
需要幫助嗎?
錯(cuò)誤消息:
[類型]查詢語(yǔ)句錯(cuò)誤
[1064]您在您的SQL語(yǔ)法錯(cuò)誤;檢查對(duì)應(yīng)到您的MySQL服務(wù)器版本的手冊(cè),正確的語(yǔ)法附近使用“M”和suoshu_bao= '2'和is_shenhe=1'在1號(hào)線
[查詢]選擇*`nandubao`WHERE`suoshu_dianying_id`= '1'和danci='m'和suoshu_bao= '2'和is_shenhe=1
程序的消息:
[行:0059] admin.php(需要)
[線:0743]源/ admincp/ admincp_plugins.php(包括)
[行:0114]源/插件/ vgallery/ admincp.inc.php(DB::查詢
本帖最后由 hdxtx55555 于 2012-1-13 23:31 編輯
我做那個(gè)插件,有難度包和搜索欄:
這里填上文字,上傳后,到dz后臺(tái)一打開(kāi),就是那上面的錯(cuò)誤提示...
是不是程序升級(jí)了?
