[求助] 那位大哥幫我看看我這系統(tǒng)是不是出問題了,一會(huì)卡死,一會(huì)正常的
Nov 16 10:48:47 root JHSED: kd_send_message_to_kernel parameter failed, port: 0, inbuf: b4f185e0
Nov 16 10:48:58 root init: console main process (1865) killed by TERM signal
Nov 16 10:48:58 root init: tty2 main process (1866) killed by TERM signal
Nov 16 10:48:59 root saslauthd[1722]: server_exit     : master exited: 1722
Nov 16 10:49:02 root xinetd[612]: Exiting...
Nov 16 10:49:02 root kernel: Kernel logging (proc) stopped.
Nov 16 10:49:02 root rsyslogd: [origin software="rsyslogd" swVersion="5.8.10" x-pid="578" x-info="http://www.rsyslog.com"] exiting on signal 15.
Nov 16 10:49:30 root kernel: imklog 5.8.10, log source = /proc/kmsg started.
Nov 16 10:49:30 root rsyslogd: [origin software="rsyslogd" swVersion="5.8.10" x-pid="578" x-info="http://www.rsyslog.com"] start
Nov 16 10:49:31 root xinetd[612]: xinetd Version 2.3.14 started with libwrap loadavg labeled-networking options compiled in.
Nov 16 10:49:31 root xinetd[612]: Started working: 0 available services
Nov 16 10:49:33 root saslauthd[1722]: detach_tty      : master pid is: 1722
Nov 16 10:49:33 root saslauthd[1722]: ipc_init        : listening on socket: /var/run/saslauthd/mux
Nov 16 10:49:39 root JHSED: other_manager is_other_filter_install
Nov 16 10:50:17 root JHSED: kd_send_message_to_kernel parameter failed, port: 0, inbuf: af417a90
Nov 16 10:51:57 root JHSED: kd_send_message_to_kernel parameter failed, port: 0, inbuf: b0617968
Nov 16 11:04:13 root JHSED: kd_send_message_to_kernel parameter failed, port: 0, inbuf: b44196b8
Nov 16 11:26:23 root init: console main process (1865) killed by TERM signal
Nov 16 11:26:23 root init: tty2 main process (1866) killed by TERM signal
Nov 16 11:26:23 root saslauthd[1722]: server_exit     : master exited: 1722
Nov 16 11:26:24 root xinetd[612]: Exiting...
Nov 16 11:26:24 root kernel: Kernel logging (proc) stopped.
Nov 16 11:26:24 root rsyslogd: [origin software="rsyslogd" swVersion="5.8.10" x-pid="578" x-info="http://www.rsyslog.com"] exiting on signal 15.
Nov 16 11:26:49 root kernel: imklog 5.8.10, log source = /proc/kmsg started.
Nov 16 11:26:49 root rsyslogd: [origin software="rsyslogd" swVersion="5.8.10" x-pid="578" x-info="http://www.rsyslog.com"] start
Nov 16 11:26:49 root xinetd[612]: xinetd Version 2.3.14 started with libwrap loadavg labeled-networking options compiled in.
Nov 16 11:26:49 root xinetd[612]: Started working: 0 available services
Nov 16 11:26:50 root saslauthd[1719]: detach_tty      : master pid is: 1719
Nov 16 11:26:50 root saslauthd[1719]: ipc_init        : listening on socket: /var/run/saslauthd/mux
Nov 16 11:26:51 root JHSED: other_manager is_other_filter_install
Nov 16 11:27:19 root JHSED: kd_send_message_to_kernel parameter failed, port: 0, inbuf: 8b714b40
Nov 16 11:28:21 root pure-ftpd: (?@ip) [INFO] 自 116.52.8.210 的新連接
Nov 16 11:28:21 root pure-ftpd: (?@ip) [INFO] chen74135 現(xiàn)在登錄
Nov 16 11:43:25 root pure-ftpd: (chen74135@116.52.8.210) [INFO] 超時(shí) - 下回試試敲鍵時(shí)速度快一點(diǎn)
Nov 16 12:36:44 root yum[2505]: Updated: 1:perl-Pod-Escapes-1.04-141.el6_7.1.i686
Nov 16 12:36:45 root yum[2505]: Updated: 4:perl-libs-5.10.1-141.el6_7.1.i686
Nov 16 12:36:45 root yum[2505]: Updated: 1:perl-Module-Pluggable-3.90-141.el6_7.1.i686
Nov 16 12:36:45 root yum[2505]: Updated: 3:perl-version-0.77-141.el6_7.1.i686
Nov 16 12:36:47 root yum[2505]: Updated: 1:perl-Pod-Simple-3.13-141.el6_7.1.i686
Nov 16 12:36:51 root yum[2505]: Updated: 4:perl-5.10.1-141.el6_7.1.i686
Nov 16 12:36:52 root yum[2505]: Updated: kernel-headers-2.6.32-573.8.1.el6.i686
Nov 16 12:36:52 root yum[2505]: Updated: nspr-4.10.8-2.el6_7.i686
Nov 16 12:36:53 root yum[2505]: Updated: nss-util-3.19.1-2.el6_7.i686
Nov 16 12:36:53 root yum[2505]: Updated: grep-2.20-3.el6_7.1.i686
Nov 16 12:36:54 root yum[2505]: Updated: coreutils-8.4-37.el6_7.3.i686
Nov 16 12:36:54 root yum[2505]: Updated: coreutils-libs-8.4-37.el6_7.3.i686
Nov 16 12:36:55 root yum[2505]: Updated: nss-3.19.1-5.el6_7.i686
Nov 16 12:36:55 root yum[2505]: Updated: nss-sysinit-3.19.1-5.el6_7.i686
Nov 16 12:36:55 root yum[2505]: Updated: nss-tools-3.19.1-5.el6_7.i686
Nov 16 12:36:55 root yum[2505]: Updated: gawk-3.1.7-10.el6_7.3.i686
Nov 16 12:36:56 root yum[2505]: Updated: initscripts-9.03.49-1.el6.centos.2.i686
Nov 16 12:36:56 root yum[2505]: Updated: cronie-noanacron-1.4.4-15.el6_7.1.i686
Nov 16 12:36:56 root yum[2505]: Updated: cronie-1.4.4-15.el6_7.1.i686
Nov 16 12:36:57 root yum[2505]: Updated: openldap-2.4.40-7.el6_7.i686
Nov 16 12:36:57 root yum[2505]: Updated: logrotate-3.7.8-25.el6_7.i686
Nov 16 12:36:57 root yum[2505]: Updated: tmpwatch-2.9.16-5.el6_7.i686
Nov 16 12:44:16 root init: console main process (1937) killed by TERM signal
Nov 16 12:44:16 root init: tty2 main process (1938) killed by TERM signal
Nov 16 12:44:17 root saslauthd[1719]: server_exit     : master exited: 1719
Nov 16 12:44:18 root xinetd[612]: Exiting...
Nov 16 12:44:19 root kernel: Kernel logging (proc) stopped.
Nov 16 12:44:19 root rsyslogd: [origin software="rsyslogd" swVersion="5.8.10" x-pid="578" x-info="http://www.rsyslog.com"] exiting on signal 15.
Nov 16 12:44:45 root kernel: imklog 5.8.10, log source = /proc/kmsg started.
Nov 16 12:44:45 root rsyslogd: [origin software="rsyslogd" swVersion="5.8.10" x-pid="578" x-info="http://www.rsyslog.com"] start
Nov 16 12:44:45 root xinetd[612]: xinetd Version 2.3.14 started with libwrap loadavg labeled-networking options compiled in.
Nov 16 12:44:45 root xinetd[612]: Started working: 0 available services
Nov 16 12:44:47 root saslauthd[1722]: detach_tty      : master pid is: 1722
Nov 16 12:44:47 root saslauthd[1722]: ipc_init        : listening on socket: /var/run/saslauthd/mux
Nov 16 12:44:50 root JHSED: other_manager is_other_filter_install
Nov 16 13:04:03 root JHSED: kd_send_message_to_kernel parameter failed, port: 0, inbuf: 9dc1b1b0
Nov 16 13:04:06 root JHSED: kd_send_message_to_kernel parameter failed, port: 0, inbuf: b5019350
Nov 16 13:25:03 root init: console main process (1866) killed by TERM signal
Nov 16 13:25:03 root init: tty2 main process (1867) killed by TERM signal
Nov 16 13:25:03 root saslauthd[1722]: server_exit     : master exited: 1722
Nov 16 13:25:04 root xinetd[612]: Exiting...
Nov 16 13:25:05 root kernel: Kernel logging (proc) stopped.
Nov 16 13:25:05 root rsyslogd: [origin software="rsyslogd" swVersion="5.8.10" x-pid="578" x-info="http://www.rsyslog.com"] exiting on signal 15.
Nov 16 13:25:29 root kernel: imklog 5.8.10, log source = /proc/kmsg started.
Nov 16 13:25:29 root rsyslogd: [origin software="rsyslogd" swVersion="5.8.10" x-pid="578" x-info="http://www.rsyslog.com"] start
Nov 16 13:25:29 root xinetd[612]: xinetd Version 2.3.14 started with libwrap loadavg labeled-networking options compiled in.
Nov 16 13:25:29 root xinetd[612]: Started working: 0 available services
Nov 16 13:25:30 root saslauthd[1719]: detach_tty      : master pid is: 1719
Nov 16 13:25:30 root saslauthd[1719]: ipc_init        : listening on socket: /var/run/saslauthd/mux
五龍影視
解決了嗎?
