[求助] 新裝的WDCP系統(tǒng),無法連接mysql
本帖最后由 6156264 于 2012-5-28 16:02 編輯
虛擬機(jī)做的wdlinux_lnmp_32.iso系統(tǒng)
安裝的wdcp v2.3  lnmp
如果不升級到2.3就沒問題。升級到2.3就這樣了。
之前都沒問題。
就是裝過wdcdn測下卸載后,
重做系統(tǒng)后就這樣了。
  1. phpmyadmin/Documentation.txt
  2. ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2)
  3. ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2)
  4. ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2)
  5. 無法連接mysql,請檢查mysql是否已啟動及用戶密碼是否設(shè)置正確![FAILED]pping httpd:
  6. Starting httpd: (98)Address already in use: make_sock: could not bind to address [::]:8080
  7. no listening sockets available, shutting down
  8. Unable to open logs
  9. [FAILED]
  10. Stopping pure-config.pl: cat: /var/run/pure-ftpd.pid: No such file or directory
  11. kill: usage: kill [-s sigspec | -n signum | -sigspec] pid | jobspec ... or kill -l [sigspec]
  12. Starting pure-config.pl: Running: /usr/sbin/pure-ftpd --daemonize -S21 -A -c50 -B -C8 -D -E -fftp -H -I15 -L10000:8 -m4 -s -U133:022 -u100 -k99 -Z -lunix -p20000:20500 -lmysql:/www/wdlinux/etc/pureftpd-mysql.conf
  13. configuration ,wdcp install is finshed
  14. visit http://ip:8080
  15. more infomation please visit http://m.gps-cemuyi.cn
最好裝base版再裝一鍵包
嗯。那我再去裝試下。
